I would like to find a set of original valve covers with good to exc chrome.The drivers side should have the two clips for the TCS wires and the pass side should have one clip for temp sending unit.
Thanks Ray |
I may have what you need, in OK to good condition. (I personally would rechrome) Anyway, what should the firewall side end of the driver side one look like...I have several, including the raised bump, the silver dollar flat, or the flattened corner.
Correction the pass side should have the 2 TCS clips and the driver side has the one clip for temp. sender.
Ureal,not sure how to describe it to you.It will have an slight slant toward one corner.Do you have any pictures of the ones you have? thanks Ray |
I have the following:
Pass- 2 sparkwire towers, 2 inside clips, 1 outside clip Pass- no towers, no clips Pass- 2 towers, no clips Driver- 2 towers (chevelle position) 1 outside clip, slanted rear with bumpout on top inside. Driver- 2 towers (chevelle position,) no clips, slanted rear with bumpout on top inside. All need minor dolly work, and rechromed, all have drippers. Driver- 2 towers (chevelle position, but unattached) no clips, slanted rear with bumpout on top inside. Driver- 2 towers (camaro position) outside clip, slanted rear with small flat at 60* on bottom outside. Driver- 2 towers (chevelle position, but unattached) 2 inside clips, straight rear with silver dollar flat on top outside. |
Unreal,I have a lead on a pair.I will let you know if it falls through.
thanks Ray |
Curious if anybody reading this thread has knowledge of replacing broken off wiring securing "clip".....and is there any way to restore the FLASH chrome....versus full on SHOW chrome.....Chuck S Seattle
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
I'm also interested in an answer to this question. I have a one that has a short spark plug tower missing and one that has a crack in it from a dent. Both covers will need to be rechromed.
Martin Foltz 68 Camaro SS-396 L35/M20, Corvette Bronze, black vinyl top George Olsen Chevrolet San Francisco |
I thought this was covered.
https://www.yenko.net/ubbthreads/show...rev=#Post20969 Is there any updates since? ![]()
Rob '68Z, original drive train AS1 AO1 D55 J52 U17 U69 Z28 |
