Old 03-10-2010, 12:54 AM
4onthefloor 4onthefloor is offline
Default How to mount a "Fly Eye" air cleaner
I feel kind of Dumb...But I got a Nice Flyeye air cleaner & I dont know How to mount that thing... Help me please...
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers
Keystone Klassic's with Big&Little's,High Jacker Air shocks.
Old 03-10-2010, 12:56 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: How to mount a "Fly Eye" air cleaner
There were several kinds back in the day. I have a Mr/ Gasket instruction sheet I've posted before. Post a pic of what you have and I'll try and dig out the right set of instructions.
Paul III
Old 03-10-2010, 01:14 AM
I got mine from Mr.427 on ebay , I will take pic & post
Old 03-10-2010, 01:35 AM
PxTx's Avatar
Okay, well that one is similar to the Mr. Gasket, but it has a lower base.
Paul III
Old 03-10-2010, 01:36 AM
I got no instructions, how does this mount???
Old 03-10-2010, 01:59 AM
PxTx's Avatar
The Mr Gasket one I posted above came with a bracket bent just like yours. Mine had a stud and a wingnut, but does the same thinga s the bolt. See where it says bend as required...
You'll have to give it a try and adjust till it holds the base down firmly and clears the choke horn.
Paul III
Old 03-10-2010, 02:23 AM
al8apex al8apex is offline
I can't tell you how many of those nuts went down carbs in the day ...
the bridge would bend and the nut would come loose and go right down the carb ... IF you are using one loctite it
Jim R
Scottsdale, AZ
