Old 10-10-2006, 07:05 AM
Default subframe bushing tape...
What was the exact application of this tape? Does it just simply tape the bushing to the subframe to hold it in place for installation? Were all four bushings taped? what about the radiator support bushings?
I am a bit confused as to the exact application, can anyone help me out? Thanks!
Tommy M
Old 10-11-2006, 06:45 AM
L30M20 L30M20 is offline
Default Re: subframe bushing tape...
Hello, The tape is used to hold the 4 body bushings, from side to side of bushing across the top part thru the hole where the bolt goes thru, in other words, the tape ran parallel with the frame on the middle bushing. On the rear bushing it was parallel with the trans crossmember. The radiator bushings had a retainer on them thru the bolt to hold them on. Its in the Assy. Manual. The tape is similar to 1-1/2 masking tape, flat black in color. I think Paragon or Quanta has it for the Vette guys. Hope this helps, Craig
Old 10-11-2006, 06:22 PM
mrrec mrrec is offline
Tape positioning and color varies with model, assy plant, time and star alignment (it was just slapped on to hold the mounts - think about it). The tape on an untouched 9k mile LT1 Vette is natural masking tape color 1 1/2" wide as posted above. Photo attached (I hope).
Dave
Dave
www.Z16Chevelle.com
Old 10-11-2006, 07:13 PM
The pic is not working, and I was all excited to see it. I have seen remnants of the tape before on numerous Camaros but what is left is never enough to form a conclusion as to what exactly was taped to what and how. I am going to replicate the tape on the bushings, however, I don't want to look like an idiot when it's not used correctly.
Tommy M
Old 10-11-2006, 07:46 PM
Chad's recently located Z-28 still showed the tape on one of the mounts. Maybe we can get him to post a picture of it since it is already on the lift and in the air.......
Rick
Old 10-11-2006, 08:32 PM
Tom Williams - does your 5k mile HO 6cyl Nova have this tape?
Old 10-11-2006, 11:39 PM
MosportGreen66's Avatar
Mid year corvettes had this tape... I'll dig up some restoration photos...
