Old 08-05-2005, 09:47 AM
musclcar musclcar is offline
Default alternator cut-out wiring to disconnect help
okay on my 72 camaro i finally installed the disconnect switch and trunk mounted battery but still very unclear on wiring the alternator cut-out.now do i run a #8 wire back to the batt. side of the switch from the alternator output ??.okay here is were i'm not to sure of the wiring. on the starter the red wire from the batt. (+) wire to the alternator is that deleted when running the alternator output back to the switch ??.i've had so many people tell me different ways now i'm getting confused.
72 camaro ss 350 sbc 425hp old school day 2 build-up
Old 08-05-2005, 04:54 PM
moparts moparts is offline
Default Re: alternator cut-out wiring to disconnect help
The reason for not leaving the alt. wire in the stock location is because the alt. will feed the system and the cut off switch will not kill the car. Running the alt. wire back to the battery or the battery side of the cut off switch will kill all fire when the switch is off.
20 foot 75 hp good time at the lake
Old 08-06-2005, 12:35 AM
so your saying disconnect the batt. wire off the back of the alternator and run a new wire back to the batt. side of the disconnect.now do what do i do with the stock wire going to the alternator,this is the same wire that ends up at the batt. side of the starter solennoid.should i remove this wire completely or is it tied into the harness somewere ??.
Old 08-06-2005, 05:31 PM
If the wiring is still in stock configuration, (elect. power is supplied at the starter connection) then you can just tape back the old alt. wire to the harness. Run the new one from the alt to the disconnect.
Old 08-15-2005, 03:54 AM
The only right way to do it is to run a wire from the alt. to the positive side of the battery.You also have to watch out with regualtor wiring.I run a one wire alt on my race car so it isnt an issue,but with the factory regulator you may have to wire parts of the harness direct to the battery to aviod power trying to backfeed thru the rgualtor when the battery is shut off.Good luck.
