Old 11-01-2016, 04:32 PM
bbbentley's Avatar
Default Z wheels 15X6 Rallys
https://dayton.craigslist.org/pts/5846124382.html
FULL OWNER HISTORY
Old 11-02-2016, 04:10 PM
Default Re: Z wheels 15X6 Rallys
----Cant remember! Are these wheels correct for a 1967 Chevelle as well as Camaro?.....Bill S
Old 11-02-2016, 05:34 PM
bbbentley's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: olredalert</div><div class="ubbcode-body">----Cant remember! Are these wheels correct for a 1967 Chevelle as well as Camaro?.....Bill S </div></div>
Believe they are 14x6 for those 2 cars. !5x6 are Z specific, IIR.
FULL OWNER HISTORY
Old 11-02-2016, 06:01 PM
scuncio's Avatar
scuncio scuncio is offline
DF are Z/28 only. Some big cars and Corvettes also used the 15x6 size.
Old 11-02-2016, 07:57 PM
DF was 1967 &amp; 1968 Z-28 only. Big cars in 1967 &amp; 1968 used the large DC coded 15 X 6 wheels. Early 1967 Corvettes (up to Mid October 1966 production) were b coded 15 X 6 wheels and after that date were small dc coded wheels until the end of production from what I remember.
Bill
Old 11-02-2016, 08:18 PM
----Thanks BBB! I kind of forgot the 14 vs 15 part. What wheels would be correct for my 67 El Camino with factory discs???.....Bill S
Old 11-03-2016, 02:58 AM
al8apex al8apex is offline
14&quot; on the A bodies, Nova and the non Z 67-68 Camaro's
there were drum brake versions too ... the outside look similar but the drum brake rally's will not clear the caliper, hence a disc brake version vs the drum brake versions
Jim R
Scottsdale, AZ
Old 11-03-2016, 06:26 AM
Bill,
I have a &quot;Cheat Sheet&quot; I made 30+ years ago at work. I'll look tomorrow and post here.
Bill
Old 11-03-2016, 08:34 PM
Bill,
RE: Additional 1967 Rally Wheel codes:
1967 Chevelle / El Camino SS &amp; HD (disc brakes?) 14 X 6 Wheel code: 6 (with a 1.00 offset)
1967 Camaro SS with disc brakes 14 X 6 Wheel code: DG (with .88 offset)
1967 Camaro w/ disc brakes w/o SS 14 X 5 Wheel code: DA (with a .88 offset)
No 1967 Camaro, Chevelle, or Nova came with 15&quot; Rally Wheels from the factory. (other than the Z-28 DF coded 15 X 6 as stated in my previuos post) Thank You for catching this Zedder
I hope this helps
Bill
Old 11-03-2016, 09:05 PM
Zedder's Avatar
Zedder Zedder is offline
67 Z28 came from the factory with 15 x 6 wheels
Mark
