Old 02-02-2016, 03:58 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default A/M Headers flange
I'm looking at this set of used ceramic coated Hedman headers for cheap. They have the p/s box dent in them and another dent at #2 cyl, but otherwise are real nice.
My question is, has anyone seen the round collector flange? I'm used to seeing the triangle 3 bolt one that bolts to my exhaust.
I figured for $100 you can't go wrong, but if the flange is that different I don't know if they'd work. They're 1 1/2 hr drive so I won't know until I actually see them.
Any ideas? Thanks!
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 02-02-2016, 06:49 PM
earntaz earntaz is offline
Default Re: A/M Headers flange
Dave -- I wouldn't think tet round collector would pose a problem. The collector is probably 3 or 3.5 inches and three or four bolts. The sealing surface must is still inside the collector mounting bolt holes. TAZ
Old 02-02-2016, 07:12 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Dave -- I wouldn't think tet round collector would pose a problem. The collector is probably 3 or 3.5 inches and three or four bolts. The sealing surface must is still inside the collector mounting bolt holes. TAZ</div></div>
So as long as I can pull the two sides together on a header gasket I should be good to go. That makes sense. So you think $100 is worth it? Seems like it. Dents are pretty easy to get out.
-Dave
Semper Fi!
Old 02-02-2016, 10:40 PM
The only issue I see here is after scanning through various Hedman Headers I do not see any with this style of collector. Ask whoever has these for sale to give you the Hedman part number -- sometimes stamped into the flange.
Old 02-03-2016, 10:40 AM
HawkX66's Avatar
I picked them up last night. They're Hedmans # 65001. That means they're 2&quot; primaries which is really too big for my motor, but I don't think it'll make that much of a difference on a street motor though. It should just move the torque up higher into the RPMS. Hedman says they're good for 396 up regardless of HP/Tq. It looks like someone might have welded a turbo flange on it for the collector flange or something. The 65001 come uncoated, so someone had these done after they were bought. I might convert them to the standard 3 bolt style or just fix the dent and flip them. We'll see. Except for the dent, they're in excellent condition.
-Dave
Semper Fi!
Old 02-03-2016, 12:51 PM
OK -- that explains the flange issue ... they look pretty good. TAZ
Old 02-03-2016, 05:00 PM
firstgenaddict's Avatar
I'd get some lead pack gaskets and make a 4 bolt flange for the exhaust.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 02-04-2016, 09:02 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body">I'd get some lead pack gaskets and make a 4 bolt flange for the exhaust. </div></div>
I decided that's the route I'll take. If it is a turbo flange like I think it is, gaskets should be pretty easy to source.
I just matched up the headers to my set up. I don't know why they're dented where they are. Its no where near the PS box. Might have hit something or clearanced them them for a custom rack and pinion maybe.
-Dave
Semper Fi!
Old 02-05-2016, 04:57 PM
resto4u resto4u is offline
You could also use a ball flange, requires no gasket.
Old 02-05-2016, 06:26 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body">You could also use a ball flange, requires no gasket.</div></div>
Would that bolt up to the header flange on mine or would you need to weld a new flange on?
edit: Looking at the price of a flange and two turbo gaskets, I might just convert it back to a 3 bolt. I'm seeing $22/gasket and $28 for a flange. Uh, no....
I think something like this welded on the exhaust will work if I can find something with the same bolt spread.
http://www.amazon.com/Flange-Dischar.../dp/B004X24PJ8
-Dave
Semper Fi!
