Old 11-17-2015, 02:00 PM
Enoch Enoch is offline
Banned
Default 66 67 396 427 engine hardware kit
Old 11-17-2015, 02:03 PM
Banned
Default Re: 66 67 396 427 engine hardware kit
66 and 67 Corvettes 427 425 horsepower 435 horsepower, 66 67 Chevelle and 67 Camaro 66 67 Impala engine and trans hardware kits. Every nut bolt washer and lock washer is original and unrestored and in excellent condition.
Included are :
1. 16 FP intake manifold bolts.
2. 16 f exhaust manifold bolts
3. Water pump to block mounting bolts and stud 3 tr
4. 660 thermostat housing bolts C + RSC
5. Alternator mounting hardware, A lower pivot bolt and lock nut, WB top adjusting bolt star washer and flat washer, RSC adjusting strap to intake bolt, and 3 a bracket to head mounting bolts.
6. Distributor hold down bracket and reinforcement and TR bolt
7. Transistor amplifier to fender skirt mounting bolts lock washers and nuts TR head marking
8. AS fan clutch to water pump hub mounting bolts and lock washers
9. RBW fuel pump mounting bolts
10. L timing chain cover bolts
11. L oil pan bolts
12. A in a circle oil pan drain plug
13. RBW motor mount to block bolts
14. A motor mount through bolts, flat washers and Mardsan nuts
15. O starter mounting bolts
16. E starter brace to block bolt
17. P stamped solenoid wire clip
18 RBW crankshaft pulley bolts and lock washers
19. O harmonic balancer bolt, lock washer and S stamped flat washer
20. ((ELH)) inspection cover bolts
21. E coil bolts
22. Set of 4, too short and too long RBW trans mount bolts, lock washers and flat washers
23. M bellhousing to engine block bolts
24. Tr transmission to bell housing bolts
25. CP and TR shifter to mounting bracket bolts 1100.00
Old 01-25-2016, 09:37 PM
Banned
New price for this complete kit 1100.00 shipped to the lower 48
