![]() Dedicated to the Promotion and Preservation of American Muscle Cars, Dealer built Supercars and COPO cars. |
Register | Album Gallery | Thread Gallery | FAQ | Community | Calendar | Become a Paid Member | Today's Posts | Search |
Each of these motors is all original with no monkeyed or replaced parts.
1963 283/195hp. Std bore. Complete minus carb, water pump, balancer. Ran when pulled but smoked a bit. Tonawanda block Block casting: 3794226 Block cast date: A1863 (January 18th, 1963) Engine assembly date: T0306DK (Tonawanda March 6th, 195hp with Powerglide and A/C) Distributor #: 1111015 Distributor date: 3 A 15 (1963, January 15th) $250. 1963 327/250hp. Std bore. 100% Complete. Stuck. Tonawanda block Block casting: 3782870 Block cast date: A2263 (January 22nd, 1963) Engine assembly date: T0125S (Tonawanda January 25th, 250hp with Powerglide) Intake casting: 3788244 Intake cast date: A1163 (January 11th 1963) Distributor #: 1111016 Distributor date: 2 K 15 (1962, November 15th) Carb: 3500S (Carter WCFB) Carb date: A 63 (January 1963) $450. 1964 327/300hp. Std bore. Complete minus water pump, balancer. Ran before pulled but smoked a bit. Block cast # 3782870 Block cast date: L243 Intake cast #: 3844459 Intake date: L 9 3 Distributor #: 1111016 Distributor date: 3 M 16 Heads casting #: 461 Carb #: 3720SA Carb date: M3 Carb tag p/n: 3851702 Block deck stamp: Y152190 F1230SB This is a Flint block which could be used for a Corvette. $1100. Send a PM and include your email if you'd like photos of these. I can deliver to a local shipper that you can make arrangements with. Thanks Verne |
