Old 04-16-2014, 01:37 AM
travlnz28 travlnz28 is offline
Default Original GM 67/68 Camaro Big Block Fan Shroud
This is a real GM big block fan shroud that needs a little work. It had a plastic extension riveted all the way around the outside edge. I have removed the extension but there are small holes every 4 - 6 inches around it. It has a small crack previously repaired at the lower corner. It also had two brackets riveted to the top of the shroud. Those have also been removed. Otherwise in good condition. $175 plus shipping
Old 04-16-2014, 02:30 AM
luzl78 luzl78 is offline
Default Re: Original GM 67/68 Camaro Big Block Fan Shroud
Greg, I'll take it. Jeff in nj
Old 04-16-2014, 02:59 AM
Jeff,
PM sent.
Gregg
