Old 08-21-2013, 10:48 PM
Default Motor mount issue
As many here may know, I'm building a 69 big block Nova, that was originally a 6 cyl/powerglide car.
I have the repro frame mounts, and basic rubber big block motor mounts. I knew the motor sat low, but I thought it was ok/normal. Now that I have the fan and shroud installed, it doesn't look right. I looked closer at the gap between the oil pan and the frame crossmember, and I can't slide a piece of paper between them. Obviously, the engine is sitting to low. It has the correct oil pan, so the issue is with the engine stands, or the motor mounts. Those are the only parts that determine the height of the engine.
Everything is set up like an L-78 would be. I'm stumped. Not sure what to do. There should be no need for spacers. The original big blocks fit, and this should be no different.
Has anyone dealt with this issue with a Nova or Camaro?
69 El Camino
69 Nova
C7 Vette
