Old 05-01-2010, 10:06 PM
Guest
Posts: n/a
Default 1969 Nova Transmission Tunnel Clarification
Hi Folks.
I need a clarification regarding the floor pans (transmission tunnel) in 1969 Novas in particular and third gen cars in general. With a bench seat, does the tunnel have the additional hump for a floor shift manual transmission, or is the additional hump (box?) for console-equipped cars only?
Thanks in advance.
Wayne
Old 05-02-2010, 01:27 AM
Default Re: 1969 Nova Transmission Tunnel Clarification
Bench seat, no console, no hump.
Old 05-02-2010, 01:59 AM
Guest
Posts: n/a
Thank you!!! You're definitely the boss when it comes to these cars! [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Wayne
Old 05-03-2010, 06:43 AM
You could also get buckets without a console - therefore no console hump. When running a bench seat 4 speed combo, make sure you put the hole in the right place as the shifter does not come up through the center of the tunnel. It also takes a specific boot/bezel combo that is curved to fit the contour of the tunnel.
Old 05-03-2010, 06:24 PM
Guest
Posts: n/a
Hi Guys.
Thanks for the info. I was seriously contemplating making the change in my Nova, but after making a hardware list, I think there's too much to change. And I'd likely be forced to use a bucket full of (potentially ill-fitting...I'm not going there) repro parts. The other (possible) big deal breaker for me was the steering column swap. I'm guessing a good stick shift column isn't the easiest thing in the world to find.
Thanks again folks. I appreciate your help.
Wayne
Old 05-03-2010, 07:07 PM
John Brown's Avatar
I think the 70 and later Camaro column will work on Novas too. They're pretty easy to find in floor shift versions.
John Brown
