Old 01-02-2010, 10:15 PM
dlv4540 dlv4540 is offline
Default 1968-69 396 L78 & L89 Blocks and Parts
1968 396-375HP standard bore w/ two sleeves 3965440 dated E-21-8 w/ front pad T0527MQ 18N449843 cleaned, magged and pressure tested $1250
1969 396-375HP standard bore 3955272 block dated K-4-9 cleaned and magged with front pad of T1113JH 19W356950 including 6223 steel crank, 11 to 1 pistons and 3/8 dimple rods along with 8 inch harmonic balancer $2500
1969 396-375HP 3955272 standard bore block dated L-10-9 cleaned and magged with front pad of T0107JH 19W408958 including 11 to 1 pistons and steel 6223 crankshaft $2000
1969 396-375HP stanadard bore block 3955272 dated E-23-9 cleaned and magged with front pad of T0527JD 19B388171 $1750
1969 L89 396-375HP block 3955272 dated J-14-8 cleaned and magged 30 over ready for final hone with front pad of T0527KG 19B400425 including steel 6223 crankshaft, service dated complete 3919842 aluminum heads along with 30 over 11 to 1 factory L78 pistons and 3/8 dimple rods out of a 70 402 L78 motor $6500.
330-770-2517 Can ship if you cannot pick these parts up.
Dennis Vugrinovich
