Old 07-24-2025, 07:10 PM
njsteve's Avatar
njsteve njsteve is offline
I'd do the lift pump first since the truck probably hasn't had it ever replaced. I was on rockauto and it looks just like the 6.5 lift pumps in my '95 but with a different fitting/harness connection. It's as easy as replacing a canister fuel filter. It's hanging on the frame rail midway between the bed and the cab. A properly functioning lift pump takes a ton of stress off the rest of the injection system. Check out Napa, first and see if they still have the lifetime warranty on their lift pumps.
Old 07-24-2025, 09:21 PM
Crush Crush is offline
So that’s just it and part of the injector issue is GM DID NOT install a lift pump in this Dmax version. They just have a CP3 fuel pump which is sucking fuel a long ways. This compounds the issues with the injectors .
The aftermarket offers external options, these come with extra filter and water separators designed to assist and clean fuel. There is also an internal fuel tank pump as in option , but this offers no additional external filtration. Depending on the “expert” you talk to gives pros and cons to each.
Everyone does agree that is a must have addition so I’m down the proverbial rabbit hole. If anyone has real world experience please do tell.
Truck runs great, I enjoy driving it.
Old 07-24-2025, 10:01 PM
njsteve's Avatar
Very interesting! You're telling me that the 6.5 engineers actually had ONE thing they did right?
The Following User Says Thank You to njsteve For This Useful Post:
Crush (07-24-2025)
