Old 05-13-2025, 03:34 PM
EZ Nova EZ Nova is offline
Napa, you can also call these guys @ Modern Driveline. They have a T56 package to use behind the Mopar Hellephant motor that make 1000Hp and 950 Tq.
A Hellephant make quite a good more bit Hp and Tq then your 565, and the new Challengers are what 1000lbs heavier.
'78 Z28 4sp being restored
'78 Z28 32,000 survivor, Og Yellow paint, AC.
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 05-13-2025, 04:12 PM
napa68's Avatar
napa68 napa68 is offline
A T56 would require a complete tunnel replacement. Given the extra height as well as the extra length necessary, That would interfere with the bench seat. That's a no go for me.
The Following 5 Users Say Thank You to napa68 For This Useful Post:
Arrowsmith (05-13-2025), big gear head (05-13-2025), cheveslakr (05-13-2025), dykstra (05-13-2025), olredalert (05-13-2025)
Old 05-13-2025, 07:20 PM
Good point on the length Tim. On my '66 chevelle bench seat, the tunnel mod actually created a slight interference with the center of the seat frame. It's all the way back, since I'm 6'3", and it'll only get tighter moved forward. You're going about this in a comprehensive way, which so many don't. I used an LT1 T56, which added another cost being the $400 conversion flywheel. I was lucky enough to get the clutch master and line with my tranny. You'd also need a new driveline. The speedo is another issue, which is doable on a T56 magnum, but it's not on the standard LT1 based T56, which would necessitate a GPS conversion speedo.
The Following User Says Thank You to cheveslakr For This Useful Post:
napa68 (05-13-2025)
Old 05-13-2025, 07:59 PM
GrumpyJeff's Avatar
Yep , Jody Haag is the Man to Talk Too ...
The Following User Says Thank You to GrumpyJeff For This Useful Post:
napa68 (05-13-2025)
Old 05-14-2025, 02:01 AM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Once you've powershifted a faceplated trans you will never go back.
G-Force for the win at that power level. G101 or GF5R
If synchros are necessary the GF3650 is the best fit for the tunnel and power level
Slipper clutch is the key to not smashing teeth even at way lower power levels.
All hardcore stuff but you get to keep the Man pedal !!
70 Chevelle SS-454 LS-5 M-22
The Following 2 Users Say Thank You to L78_Nova For This Useful Post:
cheveslakr (05-14-2025), napa68 (05-14-2025)
Old 05-14-2025, 12:48 PM
napa68's Avatar
I gotta admit, I've never driven a faceplated trans before. I'm sure it's addictive
Old 05-14-2025, 01:08 PM
napa68's Avatar
I have one remaining thought in the back of my head about the combination in the Nova, and that revolves around Tracey. I have the unicorn of a wife that actually likes these types of cars, and wants to drive them. She could handle the 422 powered 67 Nova (600hp) I used to have, but also made it clear she was not a big fan of the ram rod when I had it in there. While this sounds kind of morbid, I wonder if something happened to me, which cars would she keep? She digs this Nova almost as much as I do. I did get a bit of a stink eye from her when I showed her the M23 with the Long "ram rod"
She can certainly handle the TH400, and can handle a trans with synchro's. The faceplated thing, that may be where the line is. I have not had a problem with finding my way around synchro tranny's before, I just have not had a car at this power level. I also have to be honest with myself how often I am going to use the car at it's potential?
Old 05-14-2025, 01:49 PM
Too Many Projects's Avatar
"I also have to be honest with myself how often I am going to use the car at it's potential?"
I feel this is the first, and biggest, question you need to come to terms with and work from that.
Honestly ? I don't see you getting crazy and possibly crashing the car, so using the "potential" will be minimal.
If the current engine is not easily and economically feasible to de-tune to a more un-beastly and manual transmission friendly state, pickle it and the TH and install a healthy big block and manual that fits the tunnel and will handle that power level. The only extra cost downside will be another driveshaft to handle 600 +/- hp, torque and critical speed of the rpm the shaft will encounter at the given red line of the engine. You'll always have the beast waiting in the corner for whatever the future holds.
Good luck with your decision...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
napa68 (05-15-2025)
Old 05-14-2025, 01:53 PM
napa68's Avatar
Tim, what is the Hp and Tq rating on this engine?
Originally Posted by napa68 View Post
The better part of 800hp
Napa, what do you figure this motor is making Hp and Tq wise?
RPOLS3 (08-06-2025)
Old 05-15-2025, 12:13 PM
dykstra's Avatar
dykstra dykstra is offline
There's a joke in there somewhere.......
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
The Following 3 Users Say Thank You to dykstra For This Useful Post:
cheveslakr (05-15-2025), napa68 (05-15-2025), RPOLS3 (05-15-2025)
