Old 12-31-2013, 03:53 AM
67rs/ss 67rs/ss is offline
Default ? on 1967 Camaro old drag car.
I own a 67 camaro I purchased back in 05 and had fully restored between 07-09.I purchased it because I wanted to restore a 67 camaro. I picked this car for it's options, rs/ss 396/325,deluxe interior,bolero red black top,headrest bucket seats.The car had lakewood traction bars, driveshaft loop,manual choke in the dash.
A 68 12 bolt BV code 4:10 with 5 leaf springs carpet removed, rear battery.The seats had all been removed but stored inside,except driver seat,
Ok so here's the question a few months ago I was cleaning engine compartments on this car and my other 67 unrestored BB and noticed my hand was a little harder to get between the firewall of the restored car. When I took measurements the motor was an inch closer to the firewall. But for the life of me I can't see where the difference is. The engine and motor stands all measure 1 inch closer to firewall. Any ideas?
Tony
67 RS/SS L48 ERMINE WHITE
67 RS/SS L35 BOLERO RED
67 RS/SS L35 BUTTERNUT YELLOW
67 RS/SS L78 0-0
Old 12-31-2013, 05:27 PM
plumL78 plumL78 is offline
Default Re: ? on 1967 Camaro old drag car.
You must have small block frame stands.( motor stands) Look at the part that hangs off the back of the frame on each car and you will see the difference. Big block stands don't hang over as far
Old 12-31-2013, 06:09 PM
No that's not it the motor stands is one of the first things I checked to verify
it being a bb car, but I double checked and looks just like the other bb car. I
also check the sb car I see what you were referring to that they hang over a bit more.
Heck I even check wheel base 108". It's like everything attached to the frame rails
has been moved back.
67 RS/SS L78 0-0
Old 12-31-2013, 07:27 PM
Got any pics. of the mount
Old 12-31-2013, 07:49 PM
It sounds like this car was raced at one time. Any chance they cheated and moved the engine/trans back to locate some weight rearwards? Seems like a lot of work for only an inch which I doubt would make much difference. How is the trans mount/crossmember? Does the driveshaft look shortened?
Old 12-31-2013, 09:15 PM
69 Post Sedan's Avatar
Phil Brewer's blue L89 1968 Nova that raced pure stock class. They installed SB engine frame mounts for just that reason Rick, to get the engine back a little bit for better weight transfer.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 12-31-2013, 09:26 PM
PeteLeathersac's Avatar
Differences at the subframe mountings could create this too.
~ Pete
Old 12-31-2013, 09:44 PM
Yes it was definitely raced at one time. The car came from up north, I have a registration
for East Providence RI.
I will measure the drive shafts tomorrow.
Tony
67 RS/SS L78 0-0
Old 12-31-2013, 10:32 PM
Here's a pic of the motor stand.
67 RS/SS L78 0-0
Old 01-07-2014, 02:31 PM
So does your L78 car have a special paint code.
