Old 11-27-2008, 07:04 AM
TXZS TXZS is offline
Default Block Stamp
Opinions about this stamp?
Old 11-27-2008, 09:54 AM
mockingbird812's Avatar
Default Re: Block Stamp
Clarity of the photo is not adequate to determine broaching authenticity. Partial VIN from what I can detect is not correct. "7" should be an alpha character for the plant that the car was assembled ad there should be 2 more numbers preceding this.
Sam...
Old 11-27-2008, 10:17 AM
427freak 427freak is offline
Hey Sam
Actually this is done in the correct way for Corvettes. They did not put the S in front of the vin. Maybe because they were all built in the same place? Not saying this is or isn't THE original stamp, that would be above my pay grade.
Dana
MBTMF
Old 11-27-2008, 05:05 PM
napa68's Avatar
napa68 napa68 is offline
I agree with the broach mark on the block. The photo need to be clearer to determine authenticity or a good restoration block. The only item I am a little sceptical about is the stamps. The characters seem correct but usually the gang that hold the stamps is a little sloppy thus the numbers would not be so perfect to each other.
Just my .02
Old 11-27-2008, 07:42 PM
Dana - Corvette you say? That's one of them fandangled plastic cars I've heard about............................................. .........................................
Sam...
Old 11-27-2008, 09:16 PM
If that CON VIN configuration is correct for a Corvette, then one would assume this is supposed to be a 67 427/435. The stampings look good to me, but have to agree with Sam that a clearer picture is necessary to get a good look at the machined surface.
Bill Pritchard
Old 11-27-2008, 10:30 PM
Yes Sam, there is something besides steel out there. Once you have had a midyear it is hard to get it out of your blood, especially a big block. That glass does itch though when you sand it. I like steel too.
Dana
MBTMF
Old 11-28-2008, 02:36 AM
Glass is fun to work with... sometimes LOL!
Old 11-28-2008, 11:03 PM
TimG TimG is online now
The picture is not clear enough to see a broach. I compared to other '67 Corvettes in my picture library and I think the stamps look good. I'm comfortable with the "7" in the VIN and it should have only seven digits in the vin.
Old 11-29-2008, 04:45 AM
JohnZ JohnZ is offline
That '67 Corvette was built on February 13, 1967; the engine build date is October 13th, 1966, and the suffix indicates an L-71 (427/435hp) with K-19. I'm not comfortable with an engine sitting around at St. Louis for four months before going in a car; it'd be a stretch to call that anywhere near a normal time span. What's the casting number and date?
'69 Z/28
Fathom Green
CRG
