Old 10-09-2006, 04:29 PM
Default Re: 67 Z small journal crank
Hey Dennis.....good info. Those little motors screamed!! The crank with the hub only needed the hub to mount the pulley to. Jenkins gave us a lesson on the harmonics of all that stuff a long time ago. I remember the old days when everybody took the 283 and made them into 301's. After that GM decided that was a good idea so they did it in 67. If I remember correctly wasn't that a 125 over bore on the 283 block. Don't feel bad, I just ordered my first pair of glasses. Can't see to read. And my wife said I must be hard of hearing also!
Old 10-09-2006, 09:52 PM
kwhizz kwhizz is offline
Can't see to read. And my wife said I must be hard of hearing also! Sam
And "What" else...........
Ken
Old 10-11-2006, 12:06 AM
You are being naughty Ken!!!
Old 10-11-2006, 02:19 AM
69RSZ 69RSZ is offline
this is the casting number of my CE 302 engine 512,jerrys book says it should be a 657 block?
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 02:20 AM
pic of the notched crank.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 02:22 AM
correct heads though
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 02:24 AM
the block is dated Aug 68,any thoughts? its definitly not a 4 bolt its 2 bolt main small journal.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 02:26 AM
pic of the date
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 02:29 AM
top of motor with crankcase ventIt also has the o stamping on the rocker arms.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 10-11-2006, 03:43 AM
Denis Denis is offline
decodes as early 69-73 small journal 2-barrel 327 block, consistent with the J-10-8 (12/10/8) casting date.
and now for something completely different:
for all you other blind 40-somethings out there, the latest issue of hemmings muscle machines mentions a new product which is safety glasses with built-in reading magnification at all the popular levels: 1.5, 2.0, 2.5, etc. cost is 15.00/pr -- i called and ordered a coupl'a pair (need the second pair to find the first). will be indispensable in the shop. available from usa weld 1-800-USA-WELD.
