Old 12-03-2003, 07:46 PM
JoeC JoeC is offline
Default Re: Royal and Motion
Roger, nice pictures! [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
where are they from?
Old 12-03-2003, 07:50 PM
copo9566aa copo9566aa is offline
Hi-Perf Cars Magazine oct 1967 [img]/ubbthreads/images/graemlins/burnout.gif[/img] [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 12-03-2003, 10:37 PM
You don't see many color pictures like that [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Motion had some products that he called "Top Cat".
Royal had the "Bob Cat"
I wonder if there was a relation?
Old 12-04-2003, 02:00 AM
PxTx's Avatar
PxTx PxTx is offline
That shot of the rear with the "GM" tag is certainly Atco, NJ. It still hasn't changed much and pretty much looks the same.
Paul
Paul III
Old 12-04-2003, 02:36 AM
This one help you [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 12-05-2003, 01:18 AM
The test [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Running in A/Stock Formula 2
(N. Y. National Speedway classifica-
tion), our GTO was badly outclassed
by such formidable competitors as
375-hp 396-cube Camaros and 375-hp
Z-16 Chevelles. With friend Joel
Kimmelman handling track relations
( since promoted from friend to pit crew
chief), Joel Rosen twisting the wrencheS
and yours truly doing the driving, the
car did amazingly weIl on its first out-
ing. Royal's driving instructions were
to idle off the line at 1100-1200 rpm
because of the 1500-rpm stall speed
converter and punch it,shifting out be-
fore the hood-mounted tach reached
the 5000-rpm marker .
Temperatures at the track ran in the
60's and the Goodyears pumped to
approximately 30 psi did a respectable
job. The first two runs of the day were
made per Royal instructions and the
time slips read 14.19-no mph, 13.87-
94, and 13.60-107 respectively. AlI
shifts were thrown at 5400 rpm which
seemed to be a little too much, as
valves started floating at about that
point. Two more runs were made
with everything left as is, except that
the engine was torque-loaded on the
line at 1400 rpm and the car driven
out real hard with shifts thrown short
at 5000-5200 rpm. The final two passes
netted us 13.59-no mph and 13.40-
108 time slips, which we thought
was just unreal for a streetstocker
running 3.90 gears and a stock hydraulic
lifter camshaft. By playing it super
sharp on the lights, we managed to put
down a whole flock of machines, in-
cluding a 375-hp Camaro, but eventu-
ally fell prey to a 12.80-second-112
mph Z-16 Chevelle.
We made a few more passes after the
trophy runs but were not able to better
the 13.40-108 time slip. The roughest
part of the day was convincing the
crowds that the car was an auto trans
model and not a manual. The Royal
reworked Turbo-Hydro bangs off pow-
er shifts like a manual box because of
a reworked valve body, increased line
pressures and some super-secret re-
placement parts. It's available from
Royal Pontiac on special order .
AlI runs were made with the air
cleaner assembly in place and with a
fresh set of Champion J-10- Y plugs.
No oil was consumed during the day's
running. The pipes were bolted up to
the Doug headers and we drove 50
miles back home. No trophy, but satis-
faction plus! [img]/ubbthreads/images/graemlins/beers.gif[/img]
By M L Schorr.
Old 12-05-2003, 09:14 PM
JLP JLP is offline
Have a copy of a Phase III Productions (Baldwin Motion) Catalog and tuneup/information book produced in 1969/1970. Called Top Cat Kit and could be purchased mail order from them. Book was $4.95 back then. It has an update from '69 to '70 and has a RA V article. You can get that article from JeffH here. It has specs for all the cars and what is the best car/class to run in. It appears to be a similar kit to the Royal Bob Cat kit as it included plugs, thin head gaskest, recurving the dist (or the weights and springs to do so) and carb rebuild information/jets/springs etc. needed to rebuild the carb. It had timing specs. I'm not home now but if interested can get more information in about a week.
Pontiac guys did get into trouble drag racing that car with the MFG plate on it. Have a couple of articles on that too.
BTW, there were books that they produced for other makes/models including Ford and Mopar.
JLP
Old 12-06-2003, 07:39 PM
Cool [img]/ubbthreads/images/graemlins/burnout.gif[/img]
In 1967 for this GTO this is the Royal Go-Go Kit.
Two Cars magazine for this Bobcat GTO Sept and Oct 1967.
Old 12-07-2003, 06:21 PM
The Royal Bobcat Go-Go Kit [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 12-07-2003, 08:01 PM
JLP JLP is offline
Not the gogo most of us think of for those years. [img]/ubbthreads/images/graemlins/naughty.gif[/img] I will scan the pages in the Phase III publication for the top cat kit. But, it will have to wait until next weekend as I am not home and won't return until next weekend.
JLP
