Old 08-19-2015, 03:39 PM
novadude novadude is offline
Default Re: munci capability through quarter mile
If you want to know the ultimate strength of a Muncie, and if it will survive in your particular car, you might as well ask how many angels can dance on the head of a pin.
What clutch?
What gear ratio?
Vehicle weight?
M20, 21 or 22?
All factory gears, case, etc, or upgraded aftermarket parts?
Tires?
Chassis set-up?
How much of the gearbox fatigue life has been "used up"?
How hard is the launch?
Does it wheelhop?
etc, etc, etc....
The simple answer is to go to the track and find out. If it breaks, fix it.
Old 08-19-2015, 03:43 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: novadude</div><div class="ubbcode-body">If you want to know the ultimate strength of a Muncie, and if it will survive in your particular car, you might as well ask how many angels can dance on the head of a pin.
What clutch?
What gear ratio?
Vehicle weight?
M20, 21 or 22?
Tires?
Chassis set-up?
How much of the gearbox fatigue life has been &quot;used up&quot;?
Does it wheelhop?
etc, etc, etc....
</div></div>
And a few missed power shifts !!!!
Old 08-19-2015, 05:27 PM
MarcDant's Avatar
MarcDant MarcDant is offline
What clutch?
What gear ratio?
Vehicle weight?
M20, 21 or 22?
Tires?
Chassis set-up?
Does it wheelhop?
etc, etc, etc....
</div></div>Here are some pics of my m21 input shaft as you can see the splines are bent and close to breakage.Dint even make to the track.By the way it was a less than 300.dollar hays clutch and a stock balanced flywheel with a 3-73 rear.This was in a 70 nova with a small block.Dint damage the tranny made alittle metalic noise. when I took it apart noticed 3and4 gear knocked the snap ring off the main shaft due to the sudden load.Thats why i started this thread.Was just looking for simple input from the more experienced and the people that bought these cars new.Good thing i didnt drive to the track because the hook would have cost me 5or6 hundred dollars for transportation back home.Thanks marc.
Old 08-19-2015, 07:05 PM
Stage_2's Avatar
Stage_2 Stage_2 is offline
4.56 at the time. 3.73 currently, I dont drag race it anymore. I tamed it down, smaller cam, dual plane intake, smaller carb. I also recently put in a 5spd tko600
Jeff
Old 08-20-2015, 12:31 AM
EZ Nova EZ Nova is offline
I have been 10.40's with a stock M21 behind a 396/402 BBc. 4.56 gear 9 X 29.5 slick in '69 Nova. Had a Ram clutch with 3 pads, not a mild clutch, just something we put together for a mild streetcar.
Put the wheels 3 feet in the air and streetrace/beat on weekly for 2 years. Sold it complete for a powerglide set-up.
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
