Old 12-18-2007, 12:49 AM
Old Man Old Man is offline
Default 427?
Hi guys,
Newbie here. I have a 69 Camaro SB SS clone and have been thinking about putting a 427 in it. Can someone please tell me where I can find build specs and part numbers for a 427? Which engine books to buy, web sites to go to? I need to educate myself on the 427 before I make the leap. The pic below is my 69. Thanks guys
Attachments - The Supercar Registry 307333-Nova427lessmegapixels-3.jpg 307268-Nova427lessmegapixels-2.jpg 307225-Nova427lessmegapixels.JPG
Old 12-18-2007, 12:52 AM
Nova Jed Nova Jed is offline
Default Re: 427?
There are a few Camaro books out there at Borders or Barnes and Noble. One in particular is Chevrolet by the Numbers by Alan Colvin. Should get you started on what to look for.
Old 12-18-2007, 01:08 AM
Default Re: 427?
The books-a-million by me doesn't have it but I just saw a new B&N by the house I'll have to go have a look. Thanks
Old 12-18-2007, 01:16 AM
Default Re: 427?
If you have any resto Catalogues, they have a lot of (car) specific info in them, including books. Most of the time, local book stores can get those books for you as well. Date code and specific numbers on blocks and parts can get a bit costly if the car is not original. But that depends on what you plan on doing with the car. A big block 454 crate motor is just as effective dressed up to look like a 427 as a real 427 itself. IMO, if the car is going to be a driver, take a 454 and dress it up to look like a 427. It will still give you a 425hp big block with out the dent in the piggy bank! Beautiful Camaro by the way and Welcome to the site!
Old 12-18-2007, 03:58 AM
HiHorse HiHorse is offline
Default Re: 427?
Hi guys,
Original 427's are dime a dozen, don't settle for a suburban block with a 366 crank.
Old 12-18-2007, 04:10 AM
427.060 427.060 is offline
Default Re: 427?
[quote
Real 427s are not rare by any means but "a dime a dozen"? If you find a complete rebuildable 427 for under $2500 you've done good.
James
1968 Beaumont SD396
Old 12-18-2007, 04:32 AM
Default Re: 427?
[quote
James
I'm going to buy the books and educate myself. If I were to find an engine that was supposed to be an original 427 how could verify that it is infact a true 427? Never thought about trying to find an original motor, I thought I'd just buy the correct parts and assemble it. $2,500.00 sounds pretty good for a 427 to me.
Old 12-18-2007, 02:24 PM
Unreal Unreal is offline
Default Re: 427?
Beware of 427 tall blocks, found on some larger trucks. Passenger intakes will not fit without spacers on the intake.
The 512 block was available in both 2 bolt and 4 bolt versions. If you find a full motor, great, but if you are doing a 427/425 COPO look-a-like, then you'll be changing heads, intake, carb anyway, so a block only would be a good starting point.
Old 12-18-2007, 05:43 PM
wrench wrench is offline
Default Re: 427?
Hi guys,
build your own home grown version. 454 block 396 crank 427 piston mine made 622 hp on dyno.
Old 12-18-2007, 07:37 PM
PeteLeathersac's Avatar
Default Re: 427?
Sweet piece!.
You'd be best to first check in on member 427King.. From basic 427's to an original MN Copo engine, he's often got more than a few available..
Here's a link to one of last weeks ads..
https://www.yenko.net/ubbthreads/showflat...true#Post303781
Good luck!
~ Pete
