Old 10-07-2007, 06:06 PM
jasonL78 jasonL78 is offline
Default L78 motor cam opinion's
Ok guy's looking for some input. I am going to build my 68 L78 motor this winter. I bought a complete stock short block assembly. I was told buy the guy I bought the motor from that it has this cam in it!
Crane energy part number is 11-678-5
lift 590 intake 598 exhaust
advance duration 282 intake 290 exhaust
110 lobe seperation
16 thousands valve setting
2400-6800 power band
Do you think it is to much or is this more of a race cam than a street cam. He ran 50 thousands head gaskets to lower the compression. He said he had no problem with motor running on high octane pump gas.
I could order the stock cam but I was told buy a couple of people they went with a bigger cam and it helped the performance. Just looking for some input from others.
Thanks
Old 10-07-2007, 06:10 PM
Default Re: L78 motor cam opinion's
My black Gibb nova had a cam with 627 lift in it, worked fine on the streets.
Jake is my grandson!!
Old 10-07-2007, 08:42 PM
Mr. Chevy's Avatar
The engine builder who performed the machine work on my big block did not particularly care for Crane Cams. He suggested I use a Competiton Cam. He stated that he has seen excessive lobe wear after a season of racing on some of the motors he tore apart. I have my engine rebuilt to the L78 Specs. I know Competition Cams makes a cam that has the GM L78 grind specs which is a solid lifter cam, which is what I used. I can dig into my paperwork and get the part number if you would like, don't know it off the top of my head. This cam works very well in my motor!!
Rich
Old 10-07-2007, 09:13 PM
VintageMusclecar's Avatar
Jason;
First, the part number you quoted is a Comp cams, not a Crane.
Look here.
If you are running headers, that cam should work OK. If you're running stock manifolds, go back to the factory L78 grind.
Crane makes the current favored replacement.
Next, get rid of those .050" head gaskets. Unless the block has been decked, you're going to have roughly .075" quench distance, and contrary to popular belief, that will make the engine more prone to spark rattle, or "detonation." If the block has been decked, use a .039" gasket such as the Fel-Pro 8180. If it hasn't been decked, you can use an OE style .020" steel shim head gasket to keep quench distance in check.
Eric
Old 10-08-2007, 12:05 AM
Thanks for the reply's the motor has been decked and I am running headers. As for the part number I am just going from what the guy I bought the motor from told me. He ran the 50 thousands head gaskets and told me all I would have to do was buy the correct 840 heads which I did, bolt them on and go. But since the motor is out I am going to go threw it jus to be safe! The motor has very little time on it from what he told me. Any way's thanks for all the info.
Old 10-08-2007, 02:02 AM
We have a stock L78 with headers and it works fine on 91-94 octane gas. The 4 speed and 4.10 gears also keep it from lugging down and pinging. The L78 cam is nice for the street, is gentle on the valve train, yet makes decent power
Old 10-08-2007, 04:58 AM
allcamaro's Avatar
allcamaro allcamaro is offline
Yenko Premier Member
Watch out for cams not made in the US, I know a few friends that have had to replace cams in new motors lately from a faulty cam made over seas. Seems the cams were eaten beacuse of softer metal than needed to be used with the hipo springs and high lift, but they were told with roller lifters that problem would go away.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 10-08-2007, 05:04 AM
sztuty sztuty is offline
Rich
I would second the thought about the Competition Cams blueprint grind for the original L78 chev cam
I asked the same questions a year ago (just rebuilt my stock bore L78 out of my 1968 L78 Nova in Jan 07)
Have about 500 miles on it now-it is just getting to the point where I am going to start running it hard(haven't went over 4200 rpms yet) great performer, idler, etc
My 2 cents
Ty
Old 10-08-2007, 07:28 AM
Mr. Chevy's Avatar
Ty, yes it is a great cam.. I really like it. I have had the motor done now for about 6 years and put roughly 6 thousand miles on her cruisin around town and it's been great!! One thing I would HIGHLY RECOMMEND to you is now that the motor is just about at/past it's break in point is to start running AMSOIL 20W50 full synthetic severe duty racing oil. I use it and I think it is awesome. I have noticed that my solid lifter valve train is less noisy using this oil. You can also leave it in the engine for a couple seasons if your not driving the car much.. It will not collect moisture either. I know there have been many discussions here on the board regarding motor oils and I'm sure some guys will disagree with me, but I think this stuff is "THE BOMB". It also offers excellent engine wear protection!! Just some "food for thought". Good luck with the new engine!!
Rich
Old 10-08-2007, 06:15 PM
Chevy454 Chevy454 is offline
I would advise *against* the Comp L78 blueprint cam...the Crane/GM unit is the one you want...trust me, all of us in Pure Stock have been there, done that...you need to sit down with all of your engine specs and figure out your true compression, and that will tell you where you centerline at.
