Old 04-14-2007, 12:18 AM
Default Getting Factory Aluminum Finish Back
If an aluminum part has been bead blasted, is there a way to get the factory aluminum color/finish back?
All input is appreciated!
Old 04-14-2007, 01:58 AM
kwhizz kwhizz is offline
Default Re: Getting Factory Aluminum Finish Back
Fred........After Glass Beading........Use this.....Follow the Directions and you'll probably have to do a couple of applications to "Even" out the finish and eliminate any streaking
and then it will turn out like this
Ken
Old 04-14-2007, 02:39 AM
Carb & intake look beautiful,but damn that's some nappy looking hose.
Old 04-14-2007, 02:42 AM
TDW TDW is offline
CRACKS ME UP!!!!!!! I'm laughing my A## off!!!!
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-14-2007, 04:13 AM
indyjps indyjps is offline
last months hot rod had a good product in it. Ill try ot find it when I get home.
Old 04-14-2007, 04:15 AM
YenkoYS-199Stinger YenkoYS-199Stinger is offline
There is that word again.
The aluminum looks great. I need to get some of that. The cleaner that is, not the nappy.
Chris
1967 Yenko Stinger YS-199
Southeast of Disorder
Chris
1966 Yenko Stinger YS-070
1969 Yenko Stinger YS-320
Old 04-14-2007, 04:42 AM
If you hit the manifold with plastic media after bead blasting it will level out the finish. Oven cleaner followed by dry fine steel wool also gives good results.
Old 04-14-2007, 04:55 AM
ORIGLS6 ORIGLS6 is offline
I'm a big fan of the Eagle 1 stuff. I used it on an old GM dual quad intake without blasting it and had almost the same results.
Old 04-14-2007, 05:09 AM
If the blasting was thoroughly done, shouldnt really need a product afterwards to even it out. I prefer a fine steel wool rub down after blasting:
Before
TheMuscleCarGuys.com
Old 04-14-2007, 06:18 AM
------You leaving those studs in there, RAD??? How thick a spacer are you using??? Hey, spacers are day 2, dont ya know!........Bill S
