Old 02-22-2007, 05:03 AM
Alss's Avatar
Alss Alss is offline
Default Gas siphoning
Trying to get some fuel out of my Chevelle for the Vettefest show (1/8th tank or less). I currently have a 1/4 tank maybe a line more on the guage, but runnibg it to use the fuel up is taking forever. Siphon wont work ..ideas??..if not the car will be running for a couple of hours tomorrow..any least it sounds good and smells great!!! Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-22-2007, 05:12 AM
jtower1969 jtower1969 is offline
Default Re: Gas siphoning
I put a piece of Metal tube on my Siphon( to keep the tube low and in the gas). This kept it on the bottom. I used a low gas can (round type). It may work better if you jack up the back of the car. Just keep the can lower than the gas cap, so gravity can do its thing. It did take some time to get the 4 to 5 gallons out of the car.
Old 02-22-2007, 05:13 AM
mockingbird812's Avatar
ALbert,
My recommendation to you is to FLOG it mercilessly. Make sure you do lots of this...
...this tends to use up a bit more gas AND you get to have fun!
Why not take some pictures of your antics!
Sam...
Old 02-22-2007, 05:21 AM
Alss's Avatar
ALbert,
Sam I would love to flog it , but my driveway is doubling as a stream right now as we are having a little spring thaw..I need easy way to remove about 4 gallons of gas..never thought I would have to do it any other way except by driving it...hard!!.
ALbert
Old 02-22-2007, 05:24 AM
ALbert,
you know Mockingbirds idea...sound like more fun than mine. ...
Old 02-22-2007, 06:09 AM
MosportGreen66's Avatar
Hey Al, drive to NY tomorrow... say hello...
I sent you an email to the address in your profile....
Thanks!
-Dan
Old 02-22-2007, 05:29 PM
In times that I have had to empty my tank, I have been careful and taken the return line off my fuel pump and used a longer hose to place in the Jerry Can. It will take just a couple of minutes to get the gallons out that you want. Be sure to have a fire extinguisher handy anytime you mess with the gas!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 02-22-2007, 06:30 PM
GRB GRB is offline
Around here we drill a hole in the bottom of the tank and then put a slightly over-sized metal screw back in the hole. You won't have to siphon ever again after this trick.
BTW - do this at your own risk. We, around here, are considered professionals!
Old 02-22-2007, 06:40 PM
GM-26's Avatar
GM-26 GM-26 is offline
Nick...
Old 02-22-2007, 06:49 PM
ORIGLS6 ORIGLS6 is offline
Siphoning gas? Hey, that's right up my alley!
Being from the midwest, we're experts in this exercise!!!
I have a piece of clear 1/2" fuel line about 5 feet long that's used exclusively for 'transferring fuel'! Using the old 'tried and true method' of human vacuuming, you can watch the fuel climbing through the clear line. When it reaches a point just a few inches from the 'termination end', quickly place your finger over the end and place it in the gas can. 3 - 4 gallons should only take a couple of minutes to transfer.
I came up with the idea of using clear line after NUMEROUS incidents of coughing and gagging on Hi-Test!
(For some reason I feel I'm gonna regret this. Howie?)
