Old 08-11-2006, 02:38 AM
Dusk Blue Z Dusk Blue Z is offline
Default Re: Need photo of Upper and Lower Rad Hoses for 69 Z
I took a look at the hoses from my car which I think are original, I've owned the car 27 years. My picture came out pretty bad but I can work on it if you want to see them.
The top hose does not have any writing left on it but under where the hose clamps were, you can see a BLUE stripe, that runs the whole length of the hose. The stripe is 1/8" wide and looks like it was put on with a perf. wheel. As the hose is mounted to the radiator the stripe would have been at about the 1 Oclock position and runs straight down the hose. It has 1/4" letters of A U C cut into the rubber 5 times during the whole length.
The lower hose has GMAU with 3942561SM under it printed in White, 2 1/8" from the radiator end printed straight up so you could read it. This also looks like it has the same BLUE line, but it is harder to see. The cut letters from end to end are A U A A B A U A AB
After re-reading this I think I better work on getting better pictures or just send you the hoses. Questions?
Mike
