Old 10-31-2025, 03:57 PM
caflorin caflorin is offline
Default MP Phase III Ignition
My 68 BM SS427 Phase III Corvette still has the Phase Ignition Box mounted, but is no longer being used. I suspect something went wrong with it and a previous owner decided to go back to points. I would like to get this car returned to the Phase III ignition, but I can't find a lot of info on it. From what I have found, the stock distributor was used and the coil many have been changed to work with the system. Im sure there was something that fits in where the points are mounted. Does anyone have any information about the full package MP used back in 68/69? (Distributor, pulse sensor, how to attach the wiring harness, etc). The components in box look goods, but there is an electronic smell. Pretty sure I have the skills to reproduce a circuit diagram and check out the components in the box, but would appreciate any help for anything else I might need.
Attachments - The Supercar Registry sticker.jpeg MP_BOX.jpg MP.jpg car_a.jpg
Old 10-31-2025, 04:49 PM
luzl78 luzl78 is offline
if you sell your car you could buy my
entire house in nj
caflorin (10-31-2025)
Old 10-31-2025, 05:31 PM
That cracked me up. Yep....It's certified as the First BM Phase III Corvette. I'm not going to be selling, but there are a few things I want to get back to "as built." Most are easy fixes, but I can't find much info on the mystery "MP3 Ignition system."
Old 10-31-2025, 05:53 PM
juliosz's Avatar
juliosz juliosz is offline
You could replace whatever failed but you'd likely have something else fail shortly after. The electrolytics (capacitors) and old transistors would be the likely fail points. Assuming this system works like factory TI, you might want to consider replacing your old electronics and adapt one of the TI replacement boards you can buy from any good Corvette parts supplier.
The Following 4 Users Say Thank You to juliosz For This Useful Post:
69M22Z (10-31-2025), caflorin (11-01-2025), RobR (10-31-2025), Xplantdad (10-31-2025)
Old 10-31-2025, 06:07 PM
RobR RobR is offline
This ^^^^^^
Or clean up the ignition box and wires that you have and mount it on the inner fender or firewall and mount an MSD 6A box in an inconspicuous spot under the dash near the glove box, so it looks the part with a more modern electronic ignition for reliability.
The Following 4 Users Say Thank You to RobR For This Useful Post:
69M22Z (10-31-2025), caflorin (11-01-2025), L78_Nova (10-31-2025), Xplantdad (10-31-2025)
Old 10-31-2025, 06:23 PM
hogdaddy hogdaddy is offline
Post #22 has some good info. Your cd box looks different from most it seems.
https://www.yenko.net/forum/showthre...=110126&page=3
Here's a Mopar Motion ignition.
https://www.ebay.com/itm/364929264623
67 Convertible T-1
The Following User Says Thank You to hogdaddy For This Useful Post:
Old 10-31-2025, 06:27 PM
Originally Posted by RobR View Post
This ^^^^^^
All good ideas. The box I have is back in its front fender wall spot. The ignition does not have to go back to the MP immedicatley, but I do want to get it back to the as built system. Hoping to hear from someone who is still running it and can send me some parts specs.
Old 10-31-2025, 10:25 PM
Show us some pics of the car!
I bet that Mopar ignition will work on your Vette all the same just needs a phase 3 sticker?
67 Convertible T-1
Old 11-01-2025, 02:01 AM
Here is a pic from a recent car show. They put it in the showroom.
The Following 14 Users Say Thank You to caflorin For This Useful Post:
169indy (11-01-2025), 69M22Z (11-01-2025), big gear head (11-01-2025), Carleen (11-01-2025), dykstra (11-01-2025), earntaz (11-01-2025), hogdaddy (11-01-2025), juliosz (11-01-2025), L78_Nova (11-03-2025), LetsFNgo (11-01-2025), olredalert (11-01-2025), PeteLeathersac (11-01-2025), Tenney (11-04-2025), Xplantdad (11-03-2025)
Old 11-03-2025, 09:16 PM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default Great Corvette
Can you post some better photos of the ignition box? Does it have any markings on it?
Marty
Tags
baldwin motion, ignition, l89
