Old 01-22-2025, 12:58 AM
Bad67300 Bad67300 is offline
I have a number of lifts with the same locking design as this one, though a different manufacturer. I always, always, always visually look to make sure I can see all 4 locking blocks pointed down before lowering the deck. If one hangs up, this is what can happen. Not saying assembly wasn't partially to blame, but operator error caused this to go beyond the point of no return.
The Following 3 Users Say Thank You to Bad67300 For This Useful Post:
67since67 (01-22-2025), azcamaros (01-22-2025), Hawkeye (01-22-2025)
Old 01-22-2025, 05:25 AM
The TITAN (MCACN) Lift in Post #17 Looks VERY Similar to my DIRECT LIFT (Owned by ROTARY, but Mfg in China) I read/looked at TITAN's web site and could find ZERO regarding Country Of Mfg..............
I have two DIRECT LIFT 4 post Lifts. Neither are anchored to my level concrete floor.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-22-2025, 12:40 PM
A friend that was there said when they had lifted the car up one guy said he didn’t think one lock had locked. The other guy went to lift it but instead that one leg lifted up and the tipping started. From my experience that lifting happens when you release the pressure.
The Following 7 Users Say Thank You to Charley Lillard For This Useful Post:
67since67 (01-23-2025), azcamaros (01-22-2025), dykstra (01-22-2025), McCune (01-22-2025), olredalert (01-22-2025), PeteLeathersac (01-22-2025), Too Many Projects (01-22-2025)
Old 01-22-2025, 02:59 PM
Steve Shauger's Avatar
Administrator
Exactly!
www.vintagecertification.com
Old 01-29-2025, 03:26 AM
Rsconv68 Rsconv68 is offline
Pretty sure that’ll change every lift safety protocol and setup at every show moving forward.
Old 01-29-2025, 10:25 AM
x33rs x33rs is offline
My 4 post is an Advantage. I have noticed if I'm not pushing down on the release hard enough one of the locks might not release all the way, then when I lower it, it catches. Becomes pretty obvious, Ive done that a couple of times. It's never lifted a leg or tilted the lift but it's something that needs paid attention to. It moves so slow it would be hard to get in trouble with it without noticing somethings off before it becomes irreversible.
I've been using mine for several years and happy with it, very robust compared to a couple other brands I looked at down there last weekend.
The Following 2 Users Say Thank You to x33rs For This Useful Post:
7TL34 (01-30-2025), PeteLeathersac (01-30-2025)
Old 01-29-2025, 01:24 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
We have a Titan 4 post (our son won it at MCACN years ago). Not made in USA. We have had zero issues with it and it is not anchored to the floor. I agree with Charlie's and others comments regarding the locks not releasing all the way prior to lowering - something you have to be aware of when lowering the car. From my experience it is something that you will notice immediately if paying attention.
Jake Dykstra
Dykstra Motorsports
dykstra (01-29-2025), PeteLeathersac (01-30-2025)
Old 01-29-2025, 03:48 PM
SupremeDeluxe SupremeDeluxe is offline
I have had a lot of lifts and I have 4 now. They are Auto Lift brand, made in China. Most importantly, they have mechanical locks and you can easily discern if they are locked or free.
I have heat in my floor so I can't anchor them, but they are on dead-level and flat floor and don't shift.
My Bendpak was on a terrible floor and I had it shimmed and anchored for stability. The air locks are a menace in my experience. You have to sight it carefully when you are lowering, because they are all independent and you can hang one and have a bad day. You also have to visually check to ensure that all four are on the slots and locked when you rest it at the raised height. Someone inexperienced can easily make a mistake. It looks like the one that crashed has air locks.
The Following 2 Users Say Thank You to SupremeDeluxe For This Useful Post:
azcamaros (01-29-2025), PeteLeathersac (01-30-2025)
Old 01-30-2025, 10:19 AM
Is there a reason air locks would be attractive to someone?
Old 01-30-2025, 12:40 PM
1967 4K's Avatar
1967 4K 1967 4K is online now
Default Reason for air locks
Everything is push button these days, push button start your car, select gear, flush the toilet. I don’t own a lift but have been around them and see that locking mechanism could be an issue if not paid close attention to. Easy way to get hurt or have a lot of property damage!
Richard
1967 Camaro SS 396/375 4K
