Excellent restored radio delete coil mounting bracket. Very hard to find with rear capacitor mounting hole unthreaded. $45. Ppff
7 excellent original C2 C3 body mount washers. With W stamp. Very hard to find these that aren't all pitted. $15 each. Ppff
Three very nice original restored lower distributor gears. $25 each. Ppff
Three very nice restored P stamped parking brake cable equalizer. The reproductions do not have that P stamp on the top. $15 each. P p f f
Excellent original restored big block front engine lift hook with part number and Omega stamp and restored SB head marking mounting bolts. As nice as you're going to find. $40. PPFF
Restored 68 through 75 Corvette positive battery cable to bellhousing mounting clip with perfect original Vulcanizing and M R stamping. Won't find a nicer one. $25. Ppff
Original engine oil pan and transmission oil pan drain plugs. Included are both Styles large flat hex for Mid 68 and earlier and small hex for Mid 68 on up.
F-C $35 TR $35 D $20 RSC $20 PPFF |
Excellent original pair of assembly line installed rear emergency brake cable connectors with stepped design. Great condition. $25 for the pair. ppff
Excellent complete original restored set of Allen head door Strikers. Included are the two Allen head bolts with dimples on the rear and large attached washers.
Also included are 2 W-2 stamped 1/8" shims and 2 W-1 stamped 1/16" shims. $45 PPFF ************SOLD************ Last edited by Enoch; 10-09-2020 at 09:20 PM. |
63 through 66 Corvette battery hold down stud and Wingnut. This is an assembly line installed piece with the tapered end and rolled threads. Not the reproduction garbage that doesn't even look close. $50. Ppff
************SOLD************ Last edited by Enoch; 10-09-2020 at 09:19 PM. |
