looks like to me that the last 8 is a restamp over the eight!! my two cents worth
Compare the last 3 numbers of the Facebook “distributor number “ to the one initially posted and you will notice why the 1st one is phony. I don’t like to post the actual font issues as it’s something that I’ve got notification from people before not to do to clue in the stampers. Last edited by rszmjt; 04-08-2020 at 01:50 AM. |
Its pretty obvious the 6 and 7 in the first post are not like the other numbers
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
| The Following User Says Thank You to Jonesy For This Useful Post: | ||
68bronze (04-08-2020) | ||
Another good way to tell a restamped distributor is by the upper housing diameter, it should measure 3.810 where the numbers are and the upper undercut area for cap should measure 3.795 for approx .200 before it gets to the 3.810 diameter. If you put a distributor cap on a restamped hsg it will move on housing if you push it. They have to turn the housing down to eliminate the original numbers before restamping so diameter is smaller than original. Another good trick is to spray the number area with brake cleaner, if it’s been welded up and restamped you will see shiny areas because of the different metallurgy of housing and filler rod used.
| Thread Tools | |
| Display Modes | |
