Old 11-25-2019, 05:40 PM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default opinions of stamp on a 480 distributor, thanks
Opinions on this 480 distributor stamps. Thanks.
Old 11-25-2019, 06:28 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
I don't like it. Several things don't look right. I'm sure guys with a lot more experience than me will be along to weigh in.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 11-25-2019, 06:46 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Restamp.
Old 11-25-2019, 06:51 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Looks like a restamp for sure
Old 11-25-2019, 07:19 PM
Steve Shauger's Avatar
Administrator
yep.
www.yenko.net
www.vintagecertification.com
Old 11-25-2019, 07:47 PM
Somebody is lathe crazy but atleast they took the time to crudely "dot" the ends of the straightlines on the number 4.
Run for the hills......and stay away from it.
Paul
Old 11-25-2019, 08:14 PM
John Brown's Avatar
Agreed. Cut down a bit too much with a lathe. 3.819 to 3.813 is the nominal diameter I have found to be what distributors are normally. Any smaller than that in either direction, either across the stamped numbers or 90º out, I'd call it a fake. Most are not smaller in the area where the numbers are stamped. Be especially leery of anything coming out of Tennessee, but also Angola Indiana, although fakes are coming out of other places too.
John Brown
Old 11-25-2019, 09:15 PM
One more thing to add on this particular unit and to keep an eye out for in the future searches. The area just above the machined diameter where the numbers are is also a machined diameter. On this one, it is so corroded it now appears to be a cast diameter. This means that at one time the entire distributor was this corroded, but now the stamped area is not. You may be able to see this on other machined surfaces also.
Owned since 1978 - First Car
Old 11-25-2019, 10:56 PM
L78steve L78steve is offline
They are getting better. But this one has a way to go.
Old 11-26-2019, 12:03 AM
dvss1 dvss1 is offline
Unfortunately a restamp. That one went thru one of the big rebuilders who use steel shot to clean their parts before rebuilding. That's why it's so rough at the cap retaining area. I just sold one here and if the purchaser wants to put up the pics you will see the differences.
