Old 10-25-2019, 03:09 PM
ALLZS ALLZS is offline
Default upper a arm washer
1969 Camaro upper control arm bushing washer what is the correct plating
Old 10-25-2019, 03:49 PM
X66 714's Avatar
X66 714 X66 714 is online now
Control arm was dipped in paint after assm. Then the ball joint was installed...Joe
x77-69z28 (10-26-2019)
Old 10-25-2019, 04:29 PM
so paint them black and the bolts also
Old 10-25-2019, 08:06 PM
Edgemontvillage's Avatar
Yes.
The Following 8 Users Say Thank You to Edgemontvillage For This Useful Post:
427TJ (11-01-2019), Billohio (10-26-2019), HawkX66 (10-29-2019), mhm1966 (06-04-2025), ruralrte66 (10-25-2019), William (10-25-2019), X66 714 (10-25-2019), x77-69z28 (10-26-2019)
Old 10-26-2019, 03:21 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
What I saw when I went through the Van Nuys plant in 1990 and 1992 was the control arms already had the ball joints installed. They were dipped in the paint but left the end with the ball joint unpainted. There was a definite line where the paint stopped right before the ball joint.
On the bushing washers, I agree they were painted black.
Old 10-26-2019, 08:01 PM
William William is offline
Believe that started with the 1970 model year.
We used to stock upper control arms; they were furnished with the ball joint installed after paint less shaft, bushings and hardware.
Old 10-27-2019, 06:16 PM
enio45 enio45 is offline
nice rivot job lloyd!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-27-2019, 10:29 PM
302moz 302moz is offline
Default Upper arm
The a arm in the picture has a 67 , 68 dome style ball joint . I thought Lloyd was restoring a 69?
Old 10-27-2019, 11:38 PM
Here is a 1969 ball joint. August of 69 car.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
bergy (10-28-2019), m22mike (10-28-2019)
Old 10-28-2019, 12:11 AM
Default 69 ball joint
See the difference
