Old 07-13-2019, 11:18 PM
Plowman's Avatar
Plowman Plowman is offline
Hi Sam,all I said is that because gas is not the same today so it is not good to set it up the old way. Got it Sam.
Old 07-17-2019, 10:08 PM
Salvatore Salvatore is online now
I like to mix some 112 Sunoco in with my 93 octane Pauly. Actually even starts a little easier.
Old 07-17-2019, 11:30 PM
Plowman's Avatar
Good for you Sam. Sam do you have your vacuum can hooked up yet.
Old 07-21-2019, 07:27 PM
I run a 25% mix of VP 110 leaded with 87 no ethanol to bump me up in the 92-93 range-starts better, runs better...
FWIW the BTU's in a gallon of gasoline has gone down significantly in the last 30 years... it was 126,000 BTU prior to 1993 -- when they began mixing ethanol into the supply... the current BTU's for gasoline is listed ~114,000 BTU -as an aside... 100% Ethanol is ~ 57,000 BTU/gal
THIS MEANS that in order to get the same power you need more fuel... bigger jets... IF you are running any ethanol laced fuel you may have to increase jet size by 5-10% in order to get the same power out of the engine.
Old 07-13-2019, 08:41 PM
L78steve L78steve is offline
Lead is not relevant its octane. Lead was an octane booster but no longer.
Old 07-13-2019, 11:13 PM
Plowman's Avatar
In the older gas [leaded gas as one thing]. Today gas has more stuff in it and that changes stuff.
Old 07-17-2019, 07:52 PM
Thomas Thomas is offline
At the end of the season, I have race gas left over. I mix a couple of gallons in a tank of Premium and my engine will actually rev above 3500 without detonation.
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
Old 07-17-2019, 08:35 PM
Plowman's Avatar
They have a lot of stuff in gas for fuel injections,so they will not stick and more.
Old 07-14-2019, 01:10 AM
Burd's Avatar
Burd Burd is offline
° is on the zero key.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 07-14-2019, 05:00 AM
Plowman's Avatar
If you like it that way. I found that intake manifold vacuum on the can at idle is 10 deg max,adj can that way with a tool,runs good and cylinder temp stays down too. I hope that helps.
