Old 07-23-2017, 01:32 PM
bergy's Avatar
bergy bergy is offline
Default Windshield wiper "park" replacement
Any words of wisdom out there on where to get a new "park" solenoid assembly for my 67 Camaro wiper motor? High & low speed work fine - park is smoked.
Old 07-23-2017, 10:51 PM
I guess I am confused, happens allot now. What exactly is a park solenoid ? I thought 67, 8 and 69 use the same motor ? And the park contacts are in the gear box housing.
Mike
Old 07-24-2017, 01:21 AM
bergy's Avatar
Maybe my terminology isn't correct Mike. There's a little coil under the cover that starts the park cycle when the wipers are turned off. That coil is burned out on mine.
Old 07-24-2017, 01:29 AM
enio45 enio45 is offline
Isn't that solenoid for the WW pump??
Berry- are you talking about the plastic cover where the 2 spade connectors extend thru?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 07-24-2017, 11:23 AM
Eddie is right. That coil is to activate the washer pump cycle, one revolution of the stepping cam. The wiper motor will work without this.
When the switch is turned off the motor runs until through a ground circuit that allows the motor to run until the park contact inside the gearbox is opened and the motor is then off. The park contact opens once every revolution via a cam on the gear in the box.
Have you bench tested the motor yet ? to see if it works . It maybe a good place to start. You should be able to find a good used or NOS pump assy.
In my drawing Hi speed dc volts is 12 not 2.
Mike
Old 07-24-2017, 12:00 PM
Thats a real nice drawing Mike.
Old 07-24-2017, 01:13 PM
earntaz earntaz is offline
KISS always works ,,,
Old 07-25-2017, 02:58 AM
If it is an orig wiper, i would try to rebuild/restore it
there is a guy i cannot recall that does a lot of wipers - maybe a corvette guy....i think in Ill or Wisconsin or Minnesota - hickel or kickel - ill have to look but he does great work
he can but the housing back together with the orig or correct rivots etc......
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 07-27-2017, 09:45 PM
bergy's Avatar
Just got back from fishing for a few days on Lake Erie - belated thanks!
Old 07-28-2017, 12:36 AM
Where, and what did you catch.
Mike
