Old 07-20-2016, 07:47 PM
quik9r's Avatar
quik9r quik9r is offline
Default Bias Ply Tires
I have 8.00x14 silvertown new, they seem to have a lot of wheel weight inside and out to balance. Curious if anyone else has the same, or tricks to eliminate the some of the weight.
Quik9r
Old 07-20-2016, 07:48 PM
William William is offline
Default Re: Bias Ply Tires
Dismantle and reposition the tire on the wheel.
Old 07-20-2016, 07:51 PM
PxTx's Avatar
PxTx PxTx is offline
A Hunter Road force balancer will specifically tell you how to index a wheel and tire, if you happen to have access to one.
Paul III
Old 07-20-2016, 09:17 PM
quik9r's Avatar
Thank you both for the suggestion
Old 07-20-2016, 09:22 PM
galveston's Avatar
galveston galveston is offline
Have you tried these? I've used them on many applications with great results.
Dyna beads
Shaun
Old 07-21-2016, 03:24 AM
DynaBeads [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 08-03-2016, 09:24 PM
quik9r's Avatar
Well, sent tires to be rebalanced.... two of the four are better. The shop said other two just were not a good cast and needed the weight to get close to balance. They indexed the tires 3 times to try and get best fit. Will test drive later this week
Old 08-05-2016, 12:09 AM
Plowman's Avatar
Plowman Plowman is offline
The Hunter Road-force Balancer you only have to index the tires and rims once{the Road-force balancer is the only tire balancer that can tell a bad tire]. When the tires go down the road they deformed[like a wrinkle-wall slicks do] and the Road-Force Balancer will balance them in the deformed state.
Old 08-05-2016, 03:10 AM
How much is alot of weight? How were the wheels prior to the tires?
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 08-05-2016, 04:18 AM
quik9r's Avatar
The passenger rear tire I have included a pic... 6+ oz on the inside and 2.5 oz on the outside. The rims are true and have had radial tires in the past. I went for a drive tonight and over 60 mph vibe was bad in the ass of your pants as expected. I am looking for help to solve the issue... maybe luck of draw one or two bad tires???
