Old 05-14-2016, 10:42 PM
Default Mounting Elec Winch in My Enclosed Trailer ????
Asking to SEE PICTURES of Elec Winch/Battery Installations so as I can copy to mine.
20' 10K Pace American Shadow GT
Planning on buying ??? from Harbor Freight
Concerned about cable cutting or marring vinyl floor at rear of trailer ???
Concerned about adding additional steel under trailer
I have MIG welder and steel
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 05-15-2016, 12:18 AM
bergy's Avatar
bergy bergy is offline
Default Re: Mounting Elec Winch in My Enclosed Trailer ????
Nice looking trailer. Whatever you do, don't do with a wire cable! You can get more braid on your winch & it's safer. Also, won't mar the floor.
Old 05-15-2016, 11:28 AM
Bergy, Thanks for the reply, but I dont understand your suggestion ?????
Chuck Sharin
[email protected]
Old 05-15-2016, 11:59 AM
bergy's Avatar
There is a braided fiber (like parachute cord) line that you can get to replace the wire cable. The main advantage is that if it ever breaks, it won't snap back and injure you like steel cable will. Also, you can get a lot more of it on the winch thimble and it won't mar you floor or your car.
You can get a mounting plate (actually about a 30" long piece of steel channel) from your trailer store. It has pre-drilled holes for bolting it directly into your trailer frame.
I stopped buying expensive trailers 2 trailers ago. Mine sits outside all year & I only use it 6 or 7 times a season. I always order the best hitch, suspension and axles that they offer, but I've found it most economical to just trade a cheap one in every 4 years on a new one.
Old 05-15-2016, 05:18 PM
68l30's Avatar
68l30 68l30 is offline
I have a Superwinch installed in my Pace. I actually just spoke wth them ( Superwinch) about upgrading to the nylon rope. Their advise was not to do it. The drum with the nylon rope combo generates an excessive amount of heat and will cause issues with the brake and bearings. Now, if your winch is designed for it, no issue. My SW 3500 was not.
I fabricated some 1/4 plates formed at 90' to bolt to my center frame tube. These mount directly to the winch and center the load on the frame. Not going anywhere. I mounted my battery directly above my winch to optimize floor space.
BIG
Old 05-16-2016, 03:13 AM
COPO CARTEL COPO CARTEL is offline
Something else ...get yourself load leveling bars and sway control ...it distributes the weight on the hitch evenly ....also get a ball that's rated MORE than the Trailer capacity...( 15k or 20k )....the reason why is if you have an accident ...the insurance company can possibly deny the claim due to an underrated ball. I do not put locks on my trailer doors while in transit ...in case of a fire .... I also put a large knife just inside my trailer door to cut straps in case of a fire. You can also hide a hockey puck tracking device in case the rig is stolen. I mounted my spare in the rear just inside the door for easy access and not in the floor so I wouldn't have to move the car to get to it ... For $150 get yourself a electric tongue jack...you will be happy ...also mount a trickle charger for your battery for lights, wench, jack etc
Drive it ...Like you STOLE it !!
Old 05-16-2016, 01:46 PM
Another couple of tips. Unhook the battery in car and carry a large ABC fire extinguisher mounted just inside the door or carry it in the cab of the truck. Lastly, buy some 8' pieces of foam pipe insulation and slip on the door cables when you lower the rear door. This will protect the paint if you get too close.
Old 05-16-2016, 06:42 PM
Cut yourself 3 blocks of 6"x6" wood 12"-16" long and cut each end at a 45* angle ...that way if you have a flat while traveling ...you can pull the trailer up onto the blocks to change your tire ...this acts as your jack if you have a flat on 1 of the 2 tires
Old 05-17-2016, 02:48 PM
68l30's Avatar
Winch & battery mount...
BIG
Old 06-09-2016, 04:41 PM
I still have NOT yet mounted a winch in my trailer, but did pick up the cheap ($49.00) 2500# with remote Harbor Freight model.
Has 50 foot of cable and only two mounting holes.
You can SEE ABOVE my trailer has a Vinyl Floor. Also has three recessed aluminum tracks running front to rear where adjustable
hold down rings can be inserted/fastened.
I do NOT want the cable to drag on vinyl and mar the vinyl....How about if I had several thin nylon/plastic one foot long "bars"
attached to floor in center that cable could glide over ????. Know that they could be tripping hazard but they would be brite in color !!!
Anybody else think having battery above winch is good idea, or better on the floor over in far corner under 110Volt wall mounted
shore power box ????
THANKS for those that SHOW ME pictures or send me pictures
Chuck Sharin
[email protected]
