Old 04-05-2016, 01:45 PM
Default Small Block Chevy parts
Just purchased a 70 LT-1 CE short block and it is missing the following parts:
Oil Pump Bolt
Oil Filter Adapter with bolts
Does anyone have these for sale? Prefer original GM.
Thanks, Paul
Old 04-05-2016, 01:50 PM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default Re: Small Block Chevy parts
I have those and sny other GM eng hardware you may need. Can get you pics and price this evening. Thanks Eddie
Old 04-05-2016, 02:27 PM
Thanks, also looking for the original oil pan as well.
Paul
Old 04-05-2016, 06:22 PM
69 Post Sedan's Avatar
I too have the parts if for some reason you still need them.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-05-2016, 06:56 PM
jl8z28 jl8z28 is offline
Yenko Premier Member
The oil pump bolt looks like a exhaust manifold bolt on the one i have
Old 04-05-2016, 07:48 PM
You need oil pan or pan hardware? I do not have a pan,I have hardware and may have correct windage tray and studs.
Eddie
Old 04-05-2016, 10:39 PM
If you go looking for a Z/28 oil pan and windage tray, just be sure you don't pay big bucks unless it is a real assembly line correct oil pan. GM made a replacement pan for many years (still available after 2000) that is not assembly line correct. I have seen uninformed buyers pay $500 and up for a pan that could be bought from the dealer for $100.
Oil pan comparison
Old 04-06-2016, 12:43 PM
Oil pan and mounting hardware. The short block came with the original studs and windage tray. Are the original square socket 1/4 inch oil galley plugs still available? I had to drill out several of them to remove for block cleaning.
Thanks, Paul
Old 04-06-2016, 07:24 PM
I have oil pan hardware,oil filter mount and oil pump bolt.I will look and see what head markings I have for you to choose from. I do not have oil plugs for block. I do also have correct oil drain plug. You may want to look at timing cover to see head markings are on those bolts and I can probably match them to oil pan. Thanks Eddie
Old 04-06-2016, 10:12 PM
OK, I will check tonight and post up some pics of the fasteners and other parts.
Paul
