Old 02-07-2016, 02:58 PM
Vortecpro Vortecpro is offline
Default My Peanut Port BBC 467 Engine Build
My goal was to build a smooth idle 9.3 compression 467 BBC with peanut port heads (236 castings) then put it in my 1968 Chevelle for a drag test, yes a real drag test. Some pictures as the build went along. The center piece of my build, notice the symbol.........that sure isn't a hump there!
Old 02-08-2016, 12:41 AM
Default Re: My Peanut Port BBC 467 Engine Build
Some more pictures of the completed rods, GM 3/8 press fit. The 236 peanut port heads assembled.
Old 02-08-2016, 01:32 AM
VintageMusclecar's Avatar
Any pics of the finished intake ports?
Just curious--have you ever tried working a set of "820" heads? They have a relief cast in the chamber by the exhaust valve similar to yours
(pic snagged from the internet)
Old 02-08-2016, 12:32 PM
Yes, I have used them, Its actually a similiar chamber as a 215 or 063 or 290 with that cut out behind the valve.
Old 02-08-2016, 04:24 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Vortecpro</div><div class="ubbcode-body">Yes, I have used them, Its actually a similiar chamber as a 215 or 063 or 290 with that cut out behind the valve.</div></div>
I've used the 063s -- made good power for a first half-a$$ed open chamber design ... FWIW I am still running these heads with porting similar to Sissel (spell) mods ... TAZ
Old 02-08-2016, 08:09 PM
This will be interesting. I have a late 80´s motorhome 454 with peanut port heads that I´m going to use in my 1974 Corvette. The engine is like new inside so there is no machining required. I´ll put an aluminum intake on it but haven´t yet decided on which camshaft to use.
Keep it coming !
Anders Stålklint.
Old 02-08-2016, 10:00 PM
I should clear something up -- the 063s are NOT peanut port. Peanut port heads are normally found on truck engines to build goobs of low RPM Torque. 063s have larger oval ports. TAZ
Old 02-08-2016, 10:48 PM
Stay tuned Anders, you're gonn'a be amazed at what this engine can do. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 02-09-2016, 03:45 AM
Heres you go Anders.... more pictures, the crank GM 7416
Old 02-09-2016, 01:47 PM
novadude novadude is offline
Those look like the '69 '148' chambers.
Does anyone know the chamber size of stock '148' heads? I've seen a lot of conflicting info.
