Old 03-21-2015, 01:03 PM
Alss's Avatar
Alss Alss is offline
Default paper or plastic?
which do you guys prefer? Have to mask off the freshly painted floor/trunk in my chevelle now that I am moving on to final paint. So I'm taking a poll:
paper or plastic?
and which kind/brand [img]<<GRAEMLIN_URL>>/smile.gif[/img]
thanks
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-21-2015, 01:50 PM
BARRY BARRY is offline
Yenko Advertising Member
Default Re: paper or plastic?
both .... home depot sells hdx plastic sheeting 12x400 around 23.00 you can buy smaller
Barry Allan
Old 03-21-2015, 01:58 PM
njsteve's Avatar
njsteve njsteve is offline
I would use paper since various types of plastic are vulnerable to the solvent out-gassing of the freshly painted floors. It could result in the plastic melting to the floors in spots.
You don't want to have to redo the whole thing over again, once again. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 03-21-2015, 03:13 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">I would use paper since various types of plastic are vulnerable to the solvent out-gassing of the freshly painted floors. It could result in the plastic melting to the floors in spots.
You don't want to have to redo the whole thing over again, once again. [img]<<GRAEMLIN_URL>>/grin.gif[/img] </div></div>
AND don't use newspaper -- get paper used by pro body shops to mask off surfaces .. will not bleed through.
Old 03-21-2015, 03:48 PM
3M sheet made for auto paint is pretty inexpensive and saves a ton of time on large areas.
Old 03-21-2015, 03:53 PM
X2
Old 03-21-2015, 05:40 PM
scuncio's Avatar
scuncio scuncio is online now
I used to use paper but now use the 3M plastic on a roll. But after reading Steve's comment I may go back to paper.
Old 03-21-2015, 06:04 PM
Rixls6 Rixls6 is offline
We used the 3M plastic. Sure goes on fast.
Rick
Don't text and drive.
Old 03-21-2015, 06:14 PM
njsteve's Avatar
I don't know what material the plastic sheeting is but I had a bad experience years ago when a body shop covered the brand new convertible top on my Z11 with plastic sheet and then accidentally left a rag that had solvent residue on top of the plastic. The fumes permeated through through the plastic material and ruined the grain on the convertible top. The shop had to pay to replace the brand new top.
I imagine that the same thing would have happened if paper was used as well, but the plastic seemed to react violently with the solvent, turning into a goo that ate up the top.
Old 03-21-2015, 08:36 PM
That doesn't sound like the plastic was a bad idea; it was just a mistake by a tech. I doubt there would be an issue unless paint was sprayed directly on it.
Verne
