Old 01-31-2015, 10:06 PM
69LM1's Avatar
69LM1 69LM1 is offline
Default Thoughts on this car, real?
Not real clear on the 68 Z's but this is near me and attainable.
Rich
Rich Pern
69 Camaro COPO "Tin Soldier"
Old 01-31-2015, 10:34 PM
ds1 ds1 is offline
Default Re: Thoughts on this car, real?
4 leaf springs 8 the back. Not 5
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 01-31-2015, 10:53 PM
6t7 camaro 6t7 camaro is offline
Cool color combo, British Green with a white vinyl top. I believe the tach should redline at 6000 though.
Old 02-01-2015, 12:30 AM
69LM1's Avatar
Rear is not original I think. No traction bar ( I think it is supposed to have one?) and the car is on 4 flats so I could not get under to see. It is a 12bolt though.
Rich
Rich Pern
Old 02-01-2015, 12:43 AM
acelr8 acelr8 is offline
No traction bar on 68. Should be 6K redline. Muncie hole is a correct clue and TP sticker but are frame stands same height? Non original shifter though,
Would have had a muncie one. Jeff
Old 02-01-2015, 04:28 AM
427TJ's Avatar
427TJ 427TJ is offline
Says E70x15 tires and that sticker looks original.
Old 02-01-2015, 11:30 AM
Day2_69Z Day2_69Z is offline
is this an old drag car ?
I see cragar / centerline wheels on the front.
4 flats,, you can still see if its a 12 bolt or Dana.
Should have 4 leafs , if changed ,it probably has mono leafs for racing.
It does have the oil pressure line through the firewall but its pieced together and hanging on the booster.
They are right, it should have a 6k tach
Old 02-01-2015, 02:07 PM
69LM1's Avatar
Not so much an old drag car as an old street racer car. Car is on 4 flats on a trailer, no major rust and nothing cut out of the car (ie firewall, qtrs., etc). One fender looks like it was changed somewhere in the past and one looks original. Has a 12 bolt, but I could not get far enough under the car to see the top of the axle tube to get a code, and since I thought that the 68's had the traction bar I just figured it was not the original rear. It does have the 4 leaf springs (forgot to snap a pic of that).
Nothing original as far as engine/tranny or parts such as carb, exhaust manifolds etc.
I can get this car and a old beat up 68 drag car (it was cut up) and 1/2 a horse trailer of old parts (some for the 68's and some "race" parts) for $9,500.00
Rich
Rich Pern
Old 02-01-2015, 02:14 PM
luzl78 luzl78 is offline
That sounds like an ok price especially if there are some of those rare tire valve caps in the trailer.
Old 02-01-2015, 02:32 PM
Stefano Stefano is offline
The original fender will have factory punched holes for emblems, 350 emblems different than Z28 emblem holes. Also look in the firewall cowl area for evidence of white paint.
While I have never seen a Z28 with 14" tire sticker, I have seen non Z28s with 15" wheel sticker.........just my hands on experience.
