Old 09-20-2014, 10:01 PM
69VN's Avatar
69VN 69VN is offline
Default 1969 Camaro Z/28 For Sale Ebay
Found this intriguing but has anyone ever seen a white on white '69 Z?
http://www.ebay.com/itm/Chevrolet-Camaro...=US_Cars_Trucks
Old 09-20-2014, 10:32 PM
luzl78 luzl78 is offline
Default Re: 1969 Camaro Z/28 For Sale Ebay
That car would look better without the stripes. Very sleek white on white.
Old 09-20-2014, 11:08 PM
scuncio's Avatar
scuncio scuncio is online now
Like it a lot.
Old 09-21-2014, 12:13 AM
69LM1's Avatar
69LM1 69LM1 is offline
You dont see white Z's very often.
Rich
Rich Pern
69 Camaro COPO "Tin Soldier"
Old 09-21-2014, 01:36 AM
Not much to nit pick.
Old 09-21-2014, 01:57 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lynn</div><div class="ubbcode-body">Not much to nit pick. </div></div>the only thing is that it would look awesomer RS equipped but that's how it was born
Old 09-21-2014, 04:35 AM
Well, there are a few things to pick at.
I am a little concerned that the expert, Chip Davis (anyone know him?) thinks a trans stamped H30 was assembled August 30. That would be a June 30 built trans, which isn't unusual for an August car, but normally on the early August cars. Still, could be original to the car.
Not trying to be &quot;that guy&quot; but the other things that are admittedly nitpicking:
-shouldn't have the little vertical stainless bars on the tail lights.
-tire sticker in wrong place for Aug car
-Should have the mylar vin decal between the two ribs on the driver's door (missing on some 08A cars, but on all --the cars 08B and later).
-Shouldn't have chambered exhaust, and didn't from the factory
-door latch parts should be painted body color
-deck lid bolts should be body color
-no posi decal on deck lid
-if it is all numbers matching how was it &quot;ordered&quot; with 3.73 gears and now has a 4.10 rear
-despite Chip Davis giving a thumbs up to the all original interior, I am pretty sure the door panels are aftermarket (I will issue an apology and ask Charley to delete this post, if an expert here tells me I am wrong).
- carb looks like it was shot with Eastwood carb renew (should have sent it to Eric).
BTW, I am not sure I am buying the dealer paperwork.
for 70k, there ought to be clear pics of the pad stamping, the trans stamp and the rear axle stamp.
Car was for sale in 2010 in Louisiana (It was a Camero then) for considerably less: http://www.usedcarsfsbo.com/asp/Item...=1%2F10%2F2012
Amazingly, back in 2004, the car had a CE block, and had been through a color change. I am starting to smell a rat (or at least a bit of a mutt): http://www.camaros.net/forums/showth...=124379n675091
It IS an original trim tag, and appears to be original to the car. So it has that going for it.
Old 09-21-2014, 05:03 AM
Dicky's Avatar
Dicky Dicky is offline
Lynn, you forgot to mention that the L/H window washer
tube is out of place.... [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
DH [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Dicky
Old 09-21-2014, 05:04 AM
Z28's built after approx June couldn't get steeper gears than 3.73.
Old 09-21-2014, 05:52 AM
PeteLeathersac's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body">Z28's built after approx June couldn't get steeper gears than 3.73. </div></div>
Unless ordered w/ Copo 9510?
~ Pete
