Register | Album Gallery | Thread Gallery | FAQ | Members List | Calendar | Become a Paid Member | Search | Today's Posts | Mark Forums Read |
Until the wheels and tires get here .........the car is still sitting on Jack stands..........I've had a major problem I have been chasing for a week and finally figured it out.....After getting the car started and to get the trans filled.......I was going to run the trans thru the gears and get the fluid flowing to set the proper level........as I clicked the car into gear......it started shaking violently.........WTF!!!..........Scared the heck out of me.............I've never had this happen before.......Humm!!!.....I got a brand new driveshaft assy.......Hummm!!!.......So......I start the car again and click it into gear and look under the car.......and the rear axle assy is bouncing all over the place........HUmmm!!!.........So.....I start thinking about it and come to the conclusion that it is driveshaft related..........Now!!!........My drive line angle to driveshaft was a little more than I would have liked so I figured the universals were fighting each other as the pinion angle wasn't set and I thought that maybe I was at that point of nothing was in scync.....So.......I go ahead and raise the back of the trans to get te trans/driveshaft angle down to 3 degree's........Great.........Get everything put back together.....start the car and it still almost shook itself off the jack stands............Shut everything off and get under the car and turn the driveshaft by hand and as it was being rotated it would bind up and after putting some effort into it , it would snap past the bind point and rotate smoothly........did it again and watched the rear axle assy and I could see it moving as the shaft was going thru the "Bind" spot...........Look closer at the rear universal and I noticed that the Universal joint was installed backwards and the raised contoured portion that the grease fitting was installed in was actually hitting the pinion shaft threads........I pulled the driveshaft out and the theads were smashed in about 1/16" .........Duhhhhhh!!!!!..........I got out my little grinder and ground away the contact area.....put the shaft back in ..........started it up and clicked it in gear and ......smooth as silk.........So......I got the drivetrain angle in the "Sweet Spot" and found the problem.....I replaced both universals cause you just never know......Sometimes this car stuff is hard!!!!......LOL
![]() The Best things in life......Aren't Things |
Whoops....
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
nice catch and fix "sweet spot guy" [img]<<GRAEMLIN_URL>>/worship.gif[/img]
1970Camaro Z28 |
you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
I did!!!!......
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
I did!!!!...... </div></div> tony make it for you |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
I did!!!!...... </div></div> tony make it for you </div></div> Yep!!!.......Just a simple assembly mistake......
them guys should not make them kind of mistakes Just saying just us normal guys LOL was the front one backwards also tuff to grease when they are in backwards you should be all ready to get the Heck out of here for awhile !!
I spent the day today getting a bunch of Radiator hoses cut and fit...........I'm gonna be gone for a couple of weeks and when I get back the wheels and tires will be sitting waiting to be installed.......So.....the list of things that remain to be finished are......get the rear speakers installed......hook up the power wires to the power antenna.......Bleed the brakes one more time.....Get the Exhaust system installed .......and get the front end aligned.........heres a pic of the wheels....
Hurry back.
Rick 1966 Chevy Caprice 427-390 2012 Chevy Camaro RS Convertible ![]() |
Thread Tools | |
Display Modes | |
