Old 04-29-2013, 12:23 AM
jasonL78 jasonL78 is offline
Default 1969 chevelle shifter help or Question?
So a friend of mine bought a nice 69 chevelle 396 4sp car and is having problems with the original Muncie shifter & linkage. I have never worked on 69 shifter with the reverse lock out rod. So I have a couple of questions. This shifter has a tone of play which I don't think is correct. I tried to line it up the notches which were way off and got it to shift but it gets stuck in reverse once in a while. I advised him to change it over to a Hurst shifter gate assembly. So my question is does the hurst shifter use the reverse lock out rod? I turned him onto the kit Ground Up has with the muncie handle on the hurts gate assembly. Anyone have it in there car?
Looking for the next project.
Old 04-29-2013, 12:45 AM
Default Re: 1969 chevelle shifter help or Question?
Rick Eckenrode...you out there?
Old 04-29-2013, 02:17 AM
----Are you talking about the steering cloumn lockout rod??? Unless my memory is completely gone there is no reverse lock-out rod (so to speak) on a 69 Muncie shift assembly. The 69 style shifters have never been known for their robustness. Anyone here on the board that drove these cars the way they were supposed to be driven back in the day has probably hurt one or more. They often get caught in two gears at the same time. A Hurst shifter has no steering column lock assembly with their shifters that Im aware of. You can restore the muncie shifter but you will end up babying it and that just isnt right, IMHO!!!......Bill S
Old 04-29-2013, 06:21 AM
CC Rider's Avatar
CC Rider CC Rider is offline
My '69 has an original Muncie bench seat shifter. You don't "need" the reverse lock out rod for the Muncie or the Hurst. It is there so you can lock the shifter when the column is locked by turning the key to the lock position. I guess it was a theft deterent.
The lock out rod I'm referring to connects to the reverse lever bolted to the trans and attached to the backdrive assembly that ultimately connects to a lever on the steering column.
My shifter assembly was refurbished and works well as far as Muncie Shifters go. It's very tight for a Muncie shifter. I've learned to shift without jamming it, and I've played with the gate adjustment to help with the 2-3 shift.
Since the shifter is attached to the crossmember, it's imperative the gate adjustment be done with the suspension loaded, ie, don't raise or jack the car and let the suspension hang in the air. Make sure the stop nuts are TIGHT or the shifter will jam between gears. Keep the assembly lubed.
The folks that bought that kit from Ground Up seem to like it.
Rick
1966 Chevy Caprice 427-390
Old 04-29-2013, 09:43 AM
TDW TDW is offline
I have a Hurst CP shifter in my 69 L78 Chevelle. The reverse lock-out-back drive is hooked up and works flawlessly. I would suggest that he try to find one of the earlier model Hurst shifters. The new ones are made in China and are no-where as good as the older American made ones. I called and spoke to the "techs" at Hurst about a brand new shifter that I bought for my 55 Nomad. It was a sloppy piece of junk compared to the real Hurst ones. They said "that's the way they are now", good luck.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-29-2013, 10:38 AM
Thanks guys just trying to help a friend out. Yes I am talking about the rod that goes up to the steering column from the reverse lever or arm. You don't need it. I thought he told me in order to get the key out it had to be in reverse. If this arm is disconnected wouldn't that cause a problem. Again not my car just trying to understand this rod or anti theft device.
Thanks again
Old 04-29-2013, 10:59 AM
Ok another question? The 4 speed console I think is missing something but I am going in blind here. When I removed the top console plate because the slider was sitting funny to me? It wasn't hooked to the bottom of the top plate like my 68 nova did. It was just laying over the shifter handle. Everything was all sloppy? It has this oval piece that goes over the shifter handle and sits down around shifter boot and the slider was on the top of that then the top plate. This can't be correct is it? Is he missing something.
This isn't even my car and feel bad for my friend he paid a lot of money for this car. He has a car that won't move and the endless little things that I think the previous owner should have taken care of before he sold it. The car was just finished and none of the little bugs were worked out yet.
Old 04-29-2013, 11:33 AM
TDW TDW is offline
Jason, the collar on the steering column has to be in the home position(rotated all the way to the left), for the key to come out of the ignition. Lots of guys have removed all the mechanism for the lock-out. All you have to do is keep the collar in the home position, which can be rotated by hand when everything is disconnected.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 04-29-2013, 11:57 AM
Woj's Avatar
Woj Woj is offline
That reverse lock out rod also twists the column to activate the back-up lights on the '69 Chevelle. You can remove the rod/linkage and manually put the column into the reverse position, but you will have to disable the reverse light switch. That means no back-up lights.
Phil Woj.
Old 04-29-2013, 12:05 PM
Get yourself an original reverse lock out rod, call Crash he may have one.
The repop kits they sell will work for a short time and then you`ll get frustrated and buy an original.
Just as Tony said about the steering column must be in the home position, plus this also avoids the colomn from moving to the reverse postion....in resulting you driving with your reverse lights on.
