Old 03-27-2013, 02:59 AM
Default Safely remove old paint from plastic.
I have a real, original GM flapper valve assembly for 69 ZL2 hood.
I have owned this part since 1983 when I traded for it. Very good condition. The steel frame is easy to clean up. Sand blast cabinet.
However, the original "M" embossed Monsanto flapper is covered in orange and white paint. Yes, it came off a pace car that someone painted without removing the flapper assy.
Most of the paint will peel off with a thumbnail, but frankly, I don't want to spend three hours cleaning it.
Anything I can soak it it that will not hurt the plastic? I am guessing it is abs, but who knows.
Old 03-27-2013, 03:03 AM
Default Re: Safely remove old paint from plastic.
I personally would use plastic media at low pressure. A soak in power purple/castrol super clean would work to. See some of NJSteve's posts for the power purple insight.
Old 03-27-2013, 03:15 AM
enio45 enio45 is offline
agree, then a nice coat of SEM
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 03-27-2013, 03:59 AM
6pakdave's Avatar
6pakdave 6pakdave is offline
I had some of my interior underdash plastics in my 70GTX soda [powder] blasted with great effect. The plastics were painted in 2pak and all was removed without damaging the grain in any way. As Jason said, the guy used lower pressure, it took all of 20 mins. The plastics are not repop'd in FK5 Orange.I was more than a little paranoid about using caustic or oven products. With the soda blast they turned out really nice, good as new- literally! Dash pad,arm rests and console next!..Yes they painted all the orig FK5 pieces to "freshen-up" the interior.. DOH!!
cheers Dave
Oh me, oh my!
Reinstalled after blasting= noice!
MadMax:
You wanna get outta here...you talk to me!
Old 03-27-2013, 02:52 PM
dl7265 dl7265 is offline
I wouldn't be blasting anything. Easyoff will remove the paint and not harm the plastics.
DL
1969 Buick GS Stage 1
1970 GS455 Stage 1 4-speed
Old 03-27-2013, 03:12 PM
Agree with the Easyoff method.Especially the bio degradeable stuff.
You can control how deep you want to go by how gradually long you let it sit,then rinse off with water.
Old 03-27-2013, 08:40 PM
njsteve's Avatar
njsteve njsteve is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">I personally would use plastic media at low pressure. A soak in power purple/castrol super clean would work to. See some of NJSteve's posts for the power purple insight.
Jason </div></div>
Yes, the Purple Stuff degreaser will wash that overspray away in a matter of minutes. It doesn't hurt the plastic either. It is what all the plastic model guys use to remove old paint. It breaks the bond between the paint and the plastic surface and the paint just falls off in flakes. It is better than Easyoff oven cleaner as it does not have any propellants that can craze the plastic.
Old 03-27-2013, 10:30 PM
69VN's Avatar
69VN 69VN is offline
Lynn, I'm a painter by trade. I don't normally take paint off of plastics but there is a product called GOOF OFF. If you have some take a lint free rag and do a test spot in an inconspicuous place first before doing the rest of the plastic. DO NOT soak the part. May take some elbow grease but it should work.
SAL
Old 03-28-2013, 01:09 AM
HEMIBEE HEMIBEE is offline
Brake fluid works great also and it cleans up easy too
Rich Straub
raiv 69 judge, ra3 70 judge, 71 judge,74 SD trans am,71 cudas, 67 189 Corvette roadster, Quicksilver 68 HURST
z-10 396 camaro, 69 HEMIBEE
Old 03-29-2013, 03:48 AM
169indy's Avatar
169indy 169indy is offline
DOT-3 Brake fluid and take your time.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
