Old 01-29-2013, 03:45 AM
Default Body mount bolts and washers
Was looking at some of the pics James (firstgenaddict) has posted of his early 69 Z restoration.
https://plus.google.com/photos/112392262...mp;gpsrc=pwrd1#
First, that car is amazing. I will be glad if mine comes out half that nice. But I digress...
He shows pics of body mount bolts that have two washers by the head of the bolt. One large washer big enough to cover the bushing, and another smaller one. My late Z (08A) only had one washer for each bolt.
1. Do some have only one, while other have two?
2. Am I just missing one?
3. If they did change, when did they change to only one?
Old 01-29-2013, 02:31 PM
Default Re: Body mount bolts and washers
The black car 6335xx used only the large washer. All 67-68's used the 2 washer arrangement at the 4 under body positions. The running change for 1969 is VERY early.
Old 01-29-2013, 04:25 PM
These are the pictures Lynn was referencing.
Also here is the difference in the Original VS Repro rad support bolts and the correct set up with the retainer clip holding the busing bolt washer assembly to the rad support.
Pointed Bolt (TOP) is the ORIGINAL - the reproduction is VERY close except for the lack of point, which could be remedied fairly quickly.
Original on the right is Grade 5 whereas the replacement on the left is a Grade 8.
Last one showing the push on spring steel retainer (makes assembly much easier)
Old 01-29-2013, 06:37 PM
jasonL78 jasonL78 is offline
Are original 68 subframe bolts worth anything. I have the subframe bolts from another nova which are in real nice shape if I remeber correctly?
Looking for the next project.
Old 01-30-2013, 01:33 AM
Thanks James. I was just too lazy to post them all.
Jason: I believe there is a market for good originals.
Page 41 of the AIM shows only one washer in the main illustration. However, there is a Note in the lower right corner that shows the second washer and referes to it as "spring washer (when used)".
To confuse matters even more there is a note dated 7-15-68 indicating that "xxx4049 washer rmvd" (I can't read the first three digits).
I am guessing that is the spring washer, and, as James stated, would only be on early cars.
Old 01-30-2013, 09:40 AM
I guess I will have to dig out my originals them.
Old 02-14-2013, 04:23 PM
Anyone have a good source for thick washers for the subframe mounts? My originals are a bit pitted, and the pathetic ones that come with the new bushings are a bit thin. I have one washer in my junk pile that would work, but then it is 7/16 inch thick, and I don't need anything that thick. 3/16 or 1/4 would be great.
The washer in pic three here would work:
http://www.nastyz28.com/forum/showth...=frame+bushing
Old 02-14-2013, 05:11 PM
I will look at my originals for you.
Old 02-14-2013, 07:14 PM
Thanks Jason. Personally, I think the originals are a bit thin. I would like something just a bit thicker.
Old 02-14-2013, 10:59 PM
Lynn
AMK has them, but there min order is around 50 bux. Also poke around on
http://www.mcmaster.com/#
and
http://www1.mscdirect.com/CGI/NNSRHM...ogo-_-HomePage
Mike
