Old 06-08-2012, 08:44 AM
subyman99 subyman99 is offline
Default Re: 69 z28 302 running hot on hwy
91 octane, no lead. 3,73 gears. Radiator flows nice. I'm stumped!!
1967 Z28 survivor Black original drivetrain
1968 Z28 survivor white 40k miles
1969 Z28 survivor Rally Green 60k miles
1969 Z28 survivor Rally Green 20k miles
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Berger copo original paint 240 miles
Lots of 67-72 Chevrolet trucks
Old 06-08-2012, 09:45 AM
TDW TDW is offline
Timing a little retarded? Running a little on the lean side? What jets are in it? Vacuum advance working?
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 06-08-2012, 10:51 AM
If it is not boiling over, running erratic, pinging etc.leave it go and put some more miles on it. I would try to find some better gas if I were you or at least a lead additive. I think you can do better than 91 octane and then do what Tony suggests. With the off road cam you are making some pretty good HP.
Old 06-08-2012, 12:43 PM
MosportGreen66's Avatar
Check the timing. I also suggest a Milodon 160 degree thermostat. The thing is costly ($15 from Jegs) but the motor will run cooler. I also suggest checking the fan clutch. Like Ed said, have someone shut off the car with you standing in view of the fan. If you see it spinning with ease after the car is shut off, then the clutch needs to be rebuilt or replaced.
Old 06-08-2012, 01:00 PM
Ill check the fan tonight, ever since i got the 69 running ive been disapointed on the power this car made, it seems like there isnt much there, but then again every thing else i own is a big block. I had a 68 z28 that was stock, exept it had lower compression pistons for todays pump gas, that little car really went.
thanks again for the help!!
Matt
Old 06-08-2012, 01:58 PM
That's not unusual,especially with a bone stock 302 in front of a 3:73 @ 60mph.
Your car was intended to go quick off the line,not go for miles & miles non stop @ 60-70mph on the interstate for long periods of time,like the family station wagon.
Your reading head temp.not block temp.,so it's not as severe as you think.
Head temp.is always hotter then block and not a true internal overall reading.
Trying driving @ full speed with the heater blower motor fan on high,and see if that helps dissipate it to a lower temp.
Many other good suggestions have been listed that might help lower it.
I'm pushing a 4:10 behind my dead stock smog L-78 Chevelle,and found installing a 160° thermo & flushing the entire cooling system lowered it severely.
Old 06-08-2012, 05:33 PM
I'm reading head temp on all my big blocks in my other camaros, none run as hot as this car. I'm going to try a few things this weekend. Thanks guys
Old 06-08-2012, 06:08 PM
Hemicolt Hemicolt is offline
As long as there is nothing wrong with the tune, in the engine or bad clutch on the fan, you should look at these guide lines.
If your car runs hot at low speed or idle, but runs cool driving at highway speeds, it should be a lack of air flow as the problem.
Running cool at idle or low speed but running hot at highway speeds will suggest that the coolant is running through the system to quick and it doesn't have enough time to cool. Several things can be looked at to fix this problem. Pulley sizes can be one as the water pump may be spinning to fast. Also, installing a 165 degree stat. doesn't help with this problem. If your car runs at 185, this will mean a 165 stat. will be wide open at all times and the system will have less restriction. Using a higher temp stat. will insure that the stat. is not open all the way and will provide restriction which means the water slows down at highway speeds. Does your car have a cowl induction hood? If so, is the scoop sealed off from the engine compartment?
It's not the critic that counts, not the man who points out how the strong man stumbled or whether the doer of deeds could have done them better...
Old 06-09-2012, 12:01 AM
Matt, that car needs a rear especially with that cam. That cam probably slowed that Z up some. I run 56's with a wide ratio Muncie. My motor is stock and that really woke it up. 200 degrees like Mr. 70 said is not a killer temp IMO either.
Old 06-09-2012, 04:00 AM
just got back from a drive, i put in a radiator i had from a 68 big block, along with a deeper fan shroud i had laying around. works great. runs 175-180 on the hwy. Either the stock radiator isnt flowing good, or my fan isnt deep enough into the shroud? It sat maybe a 1/4 of the way in the shroud. Thanks guys!!
Matt
