Old 10-17-2011, 10:09 PM
Default Re: Fan Belt for 1970 Nova Deuce
Al, try this site. http://www.gastanks.com/1970/products/531/ It is Quanta restoration and they make beautiful reproductions of belts for most GM cars complete with the part number and GM stampings.
Old 10-18-2011, 05:24 AM
Al70 Al70 is offline
Thank you very much. I will check them out.
Old 10-23-2011, 05:38 PM
Jonesy's Avatar
Jonesy Jonesy is offline
My book shows
3953786 44 inches for 8cyl exc Big Block.
70 Camaro and Nova the same.
Old 10-23-2011, 05:49 PM
But the 44 inch belt will only fit a 350 LT-1 that does not have the A.I.R. smog pump. Benn there and tried it with a 44 inch belt. The books need to be revised for the correct belt which should be either 46 1/2 or 47 inches long. Thanks for the comment.
Old 10-23-2011, 07:06 PM
Jonesy's Avatar
Closest thing is see is 539130. Thats a 47.5 inch belt
3937790 is a 45.5 inch belt
These are all of of my GM parts book dated 1977.
The above belts are Nova and Camaro 396.
Old 10-24-2011, 12:51 AM
I think that the books just don't address the right belt for this car. It is probably listed as the belt for a '68 or '69 Camaro with this engine setup. I have measured around all the pulleys and it has to be something less than a 47 inch belt but 44 inches is way too short. At 47 inches, the alternator is adjusted at full tension bolt position and 44 inches will only fit around the fan and water pump, won't even come close to going around the smog pump pulley too.
