Old 08-13-2009, 11:19 PM
ss427copo's Avatar
ss427copo ss427copo is offline
Default Oil Recommendation/Solid lifter 427
Well...I'm at that crossroad of using an oil with more additives for the Camaro. I've read a bit and heard of Delo(?)
Rotelle Diesel ( )
Any thoughts or recommendation before I pull the plug?
Jeff x 2 1/2
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 08-13-2009, 11:48 PM
VintageMusclecar's Avatar
Default Re: Oil Recommendation/Solid lifter 427
I'm using Valvoline VR1 10W30 racing oil.
Old 08-14-2009, 06:47 AM
I use Rotella 20w-50 and add Cam-Shield (ZDDP) in the flat tappet motor. If the oil doesn't have the correct high level of ZDDP, you run the risk of destroying the cam, especially if you have high spring pressure. The solid roller cam motor, I use the Rotella by itself.
69 El Camino
69 Nova
C7 Vette
Old 08-15-2009, 02:02 AM
SSRSBOB SSRSBOB is offline
Use Brad Penn. It's the best out there and all of the top flight machine shops use it for engine break in. It's the old Kendall. The highest content of zinc too.
Bob
Old 08-15-2009, 03:37 AM
I have been using the Brad Penn for about 2 years now. I like it and it is real slippery. The Valvoline is real good also. The engine guys around here like the Brad Penn even a littler better than the Joe Gibbs oil. If you have a roller motor don't worry about it!
Old 08-15-2009, 03:51 AM
...real slippery...
I bin usein Rotella, and it is kinda slippery...but if Brad Penn ia real slippery I am going to git some of that stuff Sammy...
Old 08-15-2009, 08:22 AM
Or you could get Shubeck lifters and use the Castrol at Walmart.
Bob
Old 08-15-2009, 08:31 AM
MosportGreen66's Avatar
Rotella for many years here.
Old 08-15-2009, 02:22 PM
TDW TDW is offline
I suggest that you read this thread and the 2 below it. There has been exstensive testing on most brands of oil.
http://www.chevelles.com/forums/showthread.php?t=283416
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 08-15-2009, 04:34 PM
...real slippery...
[/ QUOTE ]I used the Rotella for years. When they removed more of the zinc I switched to Brad Penn. The Rotella is still probably good enough but the motor guys like the BP around here. Know what Mike.....it probably doesn't really matter especially in a solid lifter motor. Its more for $hits and giggles IMO.
