Old 02-10-2009, 06:07 AM
Default Re: really cool 70 Z28..simply the best.
Old 02-10-2009, 06:08 AM
Blue on pushrods
Old 02-10-2009, 06:14 AM
Does John know if they used what looks like #2 Permatex during assembly ? It looks like it on head bolts and screw in studs ? They used guide plates in 70?
Old 02-10-2009, 06:15 AM
Old 02-10-2009, 06:17 AM
upper radiator hose #'s
Old 02-10-2009, 06:19 AM
This front bracket almost looks like it has the remains of some grey paint near the top but at the bottom is bare steel.
Old 02-10-2009, 06:21 AM
negative bat cable ground wire bolt.
Old 02-10-2009, 07:31 AM
I may be insane but... Is that a remnant of a wax blob...indicating where the weight went?
Old 02-10-2009, 05:50 PM
------Charlie,,,Were the four valve-cover bolts exactly the same length???.........Bill S
Old 02-10-2009, 06:34 PM
Actually, grease paint, but yes, that is the mark that was determined to place the wheel weight.
I work in the paint shop at the Ford KC plant as a supplier. A few years back, we had some warranty issues with yellow spot on units. Started to do some backtracking and the grease paint (using yellow titanium dioxide) was being applied too heavy and was flinging off the wheels as it was going thought its 'road test'. The paint, although cured, was still fresh and getting stained. We saw staining from storage additives from gasoline too.
I saw a question about the sequence number... I heard someone tell it a while back and I know it holds true today. When we have a issue with a unit in the plant, we always refer to it by the 4 digit sequence number. Mind you, there are 7 digits in the sequence, but we only use 4 because a unit a sequence number 10000 old should not be in the plant!! i.e.-- 204 8647 would be yelled out as sequence # 8647.
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
