Old 12-02-2023, 04:22 PM
----The interior is gorgeous. Looks like it's totally done in leather. Am I right?....Bill S
Old 12-02-2023, 05:02 PM
jasonL78 jasonL78 is offline
Yes sir all leather!
Looking for the next project.
The Following 6 Users Say Thank You to jasonL78 For This Useful Post:
67 Nova Boy (05-14-2024), dykstra (12-03-2023), L78_Nova (12-04-2023), olredalert (12-03-2023), scuncio (12-02-2023), Too Many Projects (12-03-2023)
  #153
Old 05-13-2024, 02:14 AM
Well just about 1 year later. Fought the 4 deuce setup all fall. Almost gave up until I talked to an old timer. He said you need to go back to the basics. My issue was my left passenger side carbs were drawing alot more air than my right 2 carbs. If you placed your hand on top of the carbs while idling the motor would suck your hand in. I knew this was my problem but why? That aluminum pipe goes back to a PVC in the lifter gallery. Can anyone see what was happening?
Here is the new project!
The Following User Says Thank You to jasonL78 For This Useful Post:
  #154
Old 05-13-2024, 02:19 AM
John Brown's Avatar
So, you need to also draw pcv vacuum from the other side to even everything out?
John Brown
Old 05-13-2024, 02:41 AM
Too Many Projects's Avatar
Do you have an actual pcv in that line, to limit the amount of air the carbs can pull thru ?
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 05-13-2024, 02:52 AM
napa68's Avatar
napa68 napa68 is online now
Exactly. On my 65 fuel injected car, it does not have a PCV valve. BUT......there is an elbow what has a .090 hole to draw a vacuum in order to ventilate the crankcase.
kwhizz (05-14-2024)
  #157
Old 05-13-2024, 09:42 AM
The line does have a PCV valve in line. I had a guy add that for me when he built my linkage. A real good idea but he tapped the line into intake below throttle plates and guess what, this intake has an oil fill tube with a breather. Instant vacuum leak.This is why I couldn't adjust idle with mixture screws. While driving it and trying to stop all it did was stall. I have it pretty much set now. I just have to tap my back carb above the throttle plate is what I was thinking to add the PCV back in.
kwhizz (05-14-2024)
  #158
Old 05-17-2024, 01:16 PM
Daverde Daverde is offline
I love the old paint on your 55..
