67 camaro original rear lower shock plates needed
Need a pair of rear original lower shock plates for a 67 camaro...(Is that what they are called ? )
This is the plate that is located below the leaf spring. The U bolts/T bolts go through this plate and the lower shock mounts to this plate also. In 67 only, the shocks were both mounted on the same side of the rear....probably the same as 67 firebird .....restorable condition please... thanks SYC |
| All times are GMT. The time now is 02:50 PM. |
